write complete word instead that single char at once
5 posts / 0 new
hello
I have compiled with success this tutorial that show
how implement software UART
Now I would create a function "Software_UART("HELLO WORD)" that print all at once.
This is my actual main:
	char c = 'A';
	dbg_tx_init();
		dbg_putchar(c);
		if(++c > 'Z') c = 'A';
	return 0;
I would something like
void main(void)
  Software_UART('HELLO WORD')
whith option to have also carriage return
Thanks in advice
void Software_UART(char * str) {
  while (*str) {
     dbg_putchar(*str++);
  dbg_putchar('\n');
or similar should do what you want. (the '\n' at the end end if new line - you may want '\r' and then '\n' or perhaps to omit that bit all together?)
And before you get really confused, you would call that with this:
Software_UART("HELLO WORLD");
What you have written will not compile.
Steve A.
The subroutine to print a string is usually puts("the string") or printf("the string"); These are c library functions that have been around since c was written in 73 or so. The library functions are summarized in every c book.
For the OP the important distinction in C is that the single quote, ', delimits (marks the start and end) a single isolated character. The double quote, ", delimits a full C-string, complete with terminating null character.
Your code does not have to send that null character. The usual scheme is to step through the string until a null is found, then send a line terminator ( CR or LF or both) instead of the null, then stop sending.
