Atmega 2560: RAM Bank Switching
5 posts / 0 new
Hi
I'm looking for examples/suggestions on how I can most easily go about using the extra RAM I have.
Our application quite happily runs in the 64k available at the moment
- but I some large arrays(debug type stuff) that I could cache away in the higher bank to free up some space
I'm quite familiar with the concept
- and it makes logical sense to put this data away there
I've contemplated a readByte(char *) write(char*, val) approach
- manually defining the addresses of my static arrays
- and switching banks under the covers in there
but it seems quite heavy that way
Is there a simple way to tell the compiler/linker that a static array will be in the higher bank (so it will "overlap" the lower adress space somewhere)
-then I can just manually switch when I need to access it (ensuring that I leave space in the onchip ram into which I can transfer the data)
Hope that makes sense?
- any and all suggestions gratefully received
All the best
sd
You might get away with a named section where you explicitly set the
start address on the commandline:
$ cat test.c
int foo[10000] = { 1, 2, 3, 4 };
volatile int z[10000];
int bar[10000] __attribute__((section("overlay1")));
int
main(void)
   return foo[0] + z[1];
$ avr-gcc -mmcu=atmega1281 -Wl,--section-start=overlay1=0x802000 -o test.elf test.c
$ avr-nm --print-size test.elf
00802000 00004e20 D bar
00000130 W exit
00800200 00004e20 D foo
0000010e 00000022 T main
00805020 00004e20 B z
As you can see, the allocations for foo and bar overlap.
Jörg Wunsch
Hi Jörg
I've been trying to do that via our linker script:
- but the linker complains about the overlap
ld.exe: section .bss [00800454 -> 00800c26] overlaps section .bank2 [00800220 -> 00801d7f]
- i've defined the space in the script via
MEMORY
  text   (rx)   : ORIGIN = 0, LENGTH = 1024K
  data   (rw!x) : ORIGIN = 0x800060, LENGTH = 0xffa0
  eeprom (rw!x) : ORIGIN = 0x810000, LENGTH = 64K
/* new section below*/
  bank2  (rw!x) : ORIGIN = 0x800220, LENGTH = 48K
SECTIONS
/* stuff snipped*/
  .bank2 :
    *(.bank2*)
     __bank2_end = . ;
  }  > bank2
I'll see if I can't get the linker to ignore the overlap via command line switches
- at least it appears to have put the required object in the right place (if I do not declare anything with the attribute the build does not complain)
sd
For the second bank, don't you need 0x10000==64K> 0x2000 for its starting address?
Try giving your bank2 memory segment a different origin, like 0x820220.
As all the references are then truncated to 16 bits anyway (as it's
already done for the "date" segment), that will hopefully work.
Jörg Wunsch
