Hi clever people
I am trying to control a hobby servo from an ATMEGA16, on PortD.4 (OC1B). 16Mhz Crystal.
I need to set a PWM with a frequency of 50Hz, then adjust the PWM to adjust the servo position.
I followed a tutorial I found here:
www.mil.ufl.edu/5666/handouts/at...
I use codevision, which sets up the timer parameters using a wizard. The tutorial advises me to use the 2000 kHz timer.
(I don't really understand why this is - surely I want a 50Hz timer?)
So hopefully, there should be a PWM signal at 50Hz at this point. I then write to OCR1B to adjust the pulse width.
It totally doesn't work. :(
The servo doesn't move at all.
(the diag LEDs show that the code is being executed, and the uP is alive, just no PWM)
Here's my code:
#include#include // Declare your global variables here void main(void) { // Declare your local variables here // Input/Output Ports initialization // Port A initialization // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In // State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T PORTA=0x00; DDRA=0x00; // Port B initialization // Func7=In Func6=In Func5=In Func4=In Func3=Out Func2=Out Func1=Out Func0=Out // State7=T State6=T State5=T State4=T State3=0 State2=0 State1=0 State0=0 PORTB=0x00; DDRB=0x0F; // Port C initialization // Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In // State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T PORTC=0x00; DDRC=0x00; // Port D initialization // Func7=In Func6=In Func5=In Func4=Out Func3=In Func2=In Func1=In Func0=In // State7=T State6=T State5=T State4=0 State3=T State2=T State1=T State0=T PORTD=0x00; DDRD=0x10; // Timer/Counter 0 initialization // Clock source: System Clock // Clock value: Timer 0 Stopped // Mode: Normal top=FFh // OC0 output: Disconnected TCCR0=0x00; TCNT0=0x00; OCR0=0x00; // Timer/Counter 1 initialization // Clock source: System Clock // Clock value: 2000.000 kHz // Mode: Fast PWM top=ICR1 // OC1A output: Discon. // OC1B output: Non-Inv. // Noise Canceler: Off // Input Capture on Falling Edge // Timer 1 Overflow Interrupt: Off // Input Capture Interrupt: Off // Compare A Match Interrupt: Off // Compare B Match Interrupt: Off TCCR1A=0x22; TCCR1B=0x1A; TCNT1H=0x00; TCNT1L=0x00; ICR1H=0x00; ICR1L=0x00; OCR1AH=0x00; OCR1AL=0x00; OCR1BH=0x00; OCR1BL=0x00; // Timer/Counter 2 initialization // Clock source: System Clock // Clock value: Timer 2 Stopped // Mode: Normal top=FFh // OC2 output: Disconnected ASSR=0x00; TCCR2=0x00; TCNT2=0x00; OCR2=0x00; // External Interrupt(s) initialization // INT0: Off // INT1: Off // INT2: Off MCUCR=0x00; MCUCSR=0x00; // Timer(s)/Counter(s) Interrupt(s) initialization TIMSK=0x00; // Analog Comparator initialization // Analog Comparator: Off // Analog Comparator Input Capture by Timer/Counter 1: Off ACSR=0x80; SFIOR=0x00; PORTB.0 = 1; // Prove you are alive while (1) { PORTB.3 = 0; PORTB.1 = 1; //1st LED ON OCR1B = 1000; //Servo 0 degrees delay_ms(1000); PORTB.1 = 0; PORTB.2 = 1; //2nd LED ON OCR1B = 1500; //Servo 90 degrees delay_ms(1000); PORTB.2 = 0; PORTB.3 = 1; //3rd LED ON OCR1B = 2000; //Servo 180 degrees delay_ms(1000); } //end while 1 } //end main
Questions:
Why use the 2000 kHz timer? Is this cos it gets prescaled down to 50Hz?
Have I done enough setup to get the PWM running?
Is OCR1B the right thing to be adjusting to adjust pulse width?
The tutorial talks of setting ICR1 to 20000.
You will notice from the code that:
ICR1H=0x00;
ICR1L=0x00;
Could this be part of the problem?
In this thread:
and this thread:
There is talk of how to READ from this, and of editing the .h files, but to be honest, I don't understand it.
I notice that I can access OCR1B as a single byte, or as OCR1BL and OCR1BH, but you can't do the same for ICR1H and ICR1L.
So, how would I write the number 20000 (as instructed by the tutorial), across the two registers?
Or is this whole line of enquiry a red herring, taking me nowhere?
Any other ideas that might help?
Thanks once again
Pete
