New Bray++ Terminal version
8 posts / 0 new
(copy of a message I received per email - for your information)
Check for a new version...
https://sites.google.com/site/te...
NEW! significant speed/response improvements at higher baud rates
(test and compare with old version - please let me know about results)
NEW! LogNote when logging to file
NEW! GetTimeStr and GetDateStr functions in scripting
NEW! small bugfixes (I/O 103 error,..)
If you have a friend who is using terminal please tell him about new
version. Or if you are a member of any community (forums, groups,...)
you are more than welcome to announce a new version.
best regards, B
It was a good program already, ... my choice by default. And now it has been improved. Great!
And thanks Paddy.
A GIF is worth a thousend words   They are called Rosa, Sylvia and Tessa, You can find them https://www.linuxmint.com/
scripting feature stands out...
thanks for the update info!
always happy to "donate" to a useful cause!
Great program, been using it forever...
However, since turning up my windows fonts I get a bit of runout on the menus. Any solution(s) to that?
The only other thing I can suggest is that I'd love to see a graphing function that accepts some form of CSV and outputs a line graph.
That would be pretty handy. I've done this with text output on the Arduino (ex: submissive serial) as well as copying and pasting into excel, then plotting. But having it built in would save a lot of time...
Michael
just noticed in the Help about dialog that this rev is labeled v1.9b just like the previous version dialog box except the copyright date changed
The previous version shows at the top of the program window
Terminal v1.9b - 20091126b
The new version shows at the top of the program window
Terminal v1.9b - 20111215b
....version 1.9c ?
note to self..update all computers at once so they are all known to be in sync version wise...
I guess he forgot to bump the rev # to 1.9c.
I've long thought it's the best terminal program for non-Telnet things like serial/USB ports.
Had to revert back to Terminal v1.9b - 20091126b to use the Atmel Virtual CDC COM XPLAINED_Virtual_Com_Port.inf on a Win7 32bit pc.
The new version Terminal v1.9b - 20111215b for whatever reason would not work with it. Both versions do work with a ftdi usb serial adapter and a loop back adapter though on the same pc and the Atmel Virtual com driver on the same pc works with TeraTerm and RealTerm also.
not sure what the issue is but that is the test result on that specific Win7 pc.
