TINY10 / Store constants in flash memory and use them
3 posts / 0 new
Hi, I am trying to store some constants in flash memory of TINY10 and use them.
- Studio 5 latest version
- GCC
#include
unsigned char current_comp[3][2] PROGMEM=
{255,101},{254,101},{251,102}
In the main function, I put the following codes to use those constants.
OCR0A = pgm_read_byte(&(current_comp[1][0]));
Then, I got the following erros when ran compiler.
- illegal opcode lpm for mcu attiny10
- register number above 15 required
Any helps on this matter would be appreciated. Thanks!
- GCC
I don't think GCC has "real" support for Tiny10--and you've just uncovered one of the gotchas, as that family has different flash access mechanism than LPM.
Use ASM, or CodeVision has full support. Or ???
See https://www.avrfreaks.net/index.p...
Hi, Thank you very much for your response. I will try ASM or check other compilers to see if they work. Thank you.
