Compile script problemin Ubuntu 11.10
3 posts / 0 new
I have a starange poblem with using script I runing to handle compiling of the kernel.
The two first lines execute fine ( my own config):
make ARCH=avr32 CROSS_COMPILE=avr32-linux- wpr-rec31a_defconfig
make ARCH=avr32 CROSS_COMPILE=avr32-linux- menuconfig
while the command:
generates
make: avr32-linux-gcc: Command not found
but avr32-linux-gcc is available
user@ubuntu1010desktop:~/Desktop$ avr32-linux-gcc
avr32-linux-gcc: no input files
Life's to short for waiting on slow CPU's
For building modules, I had to change the path to the cross compiler when I went to buildroot3.0.0
the path is now:-
/buildroot-avr32-v3.0.0/output/staging/usr/avr32-linux/bin/
and the compiler is gcc so when building it calls as:-
/buildroot-avr32-v3.0.0/output/staging/usr/avr32-linux/bin/gcc
if I try and run:-
[las@ng2 ~]$ avr32-linux-gcc
I get:-
bash: avr32-linux-gcc: command not found...
[las@ng2 ~]$
When I was building the kernel, it built the compiler first and then used it in the rest of the build. I didn't need to change anything.
I hope this helps.
Thanx for the reply, I tried out from your suggestion to also add :
/home/user/buildroot-avr32-v3.0.0/output/staging/usr/avr32-linux/bin/
I already had in my path:
/home/user/buildroot-avr32-v3.0.0/output/host/usr/bin
and
/home/user/buildroot-avr32-v3.0.0/output/staging/usr/bin/
It seems to work as expected now. Not sure why but it works. Thanx again.
