cant load software to 8535 with the STK 200 why
2 posts / 0 new
Hi there
I bought 16 8535 and i cant load the software to it using the STK 200.
I am using the Code vision compilerand it works fine with the 8515 (arent they the same?).
Is there a way to load it through the ISP maybe via STK500 ( which i have also)
Or maybe can i doo that if i will build the ISP loader and it will work?
Please advise
Hello!
I am using Codevison with AT90S8535 and it works fine.
have you set up the correct chip type in the compilator settings? and
remeber to put the 8535 in the "Analog parts" socket!!!!
8515 and 8535 do not have the same pinout..
if you can read the devicecode from the codevision programmer the contact with the 8535 is OK.
//Truls
