Tiny2313 and TIMSK on a simulator
5 posts / 0 new
I've wrote following code:
      ldi r17, 1 << OCIE1A | 1 << OCIE0A ;got 0x41 in r17
      out TIMSK, r17  ;got 0x21 !!! in TIMSK
      in  r17, TIMSK  ; again 0x41 in r17
Value 0x21 I view in debugger, and timer1 behaves like there is actualy 0x21 in TIMSK register.
In Studio 4 with simulator 1 I've got 0x41 in TIMSK register, but with simulator 2 it behaves like in studio 5.
Is it a bug in simulator or there is mistake in my code?
Thank you for reporting this. There is nothing wrong with your code. This is a bug in the simulator model for ATtiny2313(A)/ATtiny4313 and will be fixed ASAP. For future reference this is bug #15217.
The program will simulate correctly but the I/O view presentation of OCIE1A and OCIE1B will be swapped in TIMSK, and TOIE1A <-> TOIE1B in TIFR.
- roland
      ldi r17, (1<<OCIE1A) | (1<<OCIE0A) ;got 0x41 in r17
I would guess that your expression does actually work. After all, you have checked the Simulator behaviour.
I can never be bothered to look up the relevant operator precedences.
Simply using parentheses ensures that your expression is what you want.
No need - it does load 0x41 into R17 as his comment says. As Roland confirms this is a bug in Sim2 (I checked 4.19 where it's also evident).
- roland
Thank you for your answer!
It was my mistake. You were right - timer behaves like there is 0x41 in TIMSK
