Hi all
Does anyone know of a codevision compatible version of an ethernet library to interface with WizNet chips?
The arduino folks have a library, and it looks quite straightforward to use - example here:
http://www.pjrc.com/teensy/td_libs_Ethernet.html
I don't want to use arduino, cos it seems like a step backward to beginner level. (or is it the future of embedded programming, and I should get used to it?)
I think some of you on here are in touch with the developer of CodevisionAVR - any news? rumours?
All I want to do is simple things - eg read a temperature sensor and show it on a web page, or switch a light on and off.
Any suggestions?
Pete
