Is this possible? I've spent most of a day debugging a problem that a stack trace would have fixed in minutes.
I'm using an xmega chip with a jtagice2.
Nope. Your best bet is to examine the memory in the region of SP and use a copy of the .map file alongside - you may be able to spot obvious return addresses and which function they reside in.
Maybe Atmel should have disabled the stack trace window, so I wouldn't get my hopes up :(
The stack trace doesn't work yet, it only shows the current call, and doesn't unwind the stack from the entry point in main(). Let's hope for a fix in the update to AVR Studio 5 (but don't hold your breath).
Jerry
