RS232 UART
5 posts / 0 new
Hello
im trying to write to Hyperterminal on my PC using RS232 UART from a STK 500. My program is
#include <90s8515.h>
#include
#include
void main(void){
UCR = 0x18;
UBRR = 0x19;
printf("\n TEST \n");
while(1){
printf("\n TEST TEST \n");
delay_ms(2000);
will this work ? Can i use a regular RS232 cable ?
My problem is that I`m not receive anything.
Regards Gunnar
We need to know which compiler, what xtal frequency. UART init depands on xtal freq.....
It looks like CodeVision. Why don't you let the Wizard do the application skeleton and chip init for you, and then put in your printf()?
BTW, CodeVision's Terminal facility is pretty good and has lots of options for low-level work.
Lee
I`m using CodeVision AVR. Is it different in IAR Embedded Workbench?
Hello every body,
Here is a piece of code that will work. This is plain 'C' no devopen etc.
To initialise the serial port
void usart0_init (void)
UBRR0h = 00;
UBRR0L = 23; // this will set the serial port to 9600 baud when the crystal connected is 3.69 MHz. See ATMEL .PDF file for actual value if you are using the 4M or 8M built-in clock
UCSR0B = 0x18; // enable receive and transmit
UCSR0C = 6; // no patiry and that stuff
Now to transmit a NULL terminated string
usart0_tramsmit (char *cptr) // this function takes a pointer to character
while (*cptr)
UDR0 = *cptr++;
while (!UCSR0A & 0x40); // wait here till transmit complete
UCSR0A = 0x40; // clear this flag for the next byte (char)
_delay_loop_1 (200); // optional if you need delay between chars
This is written for Atmega128 processor and since it has two serial ports, I am writing to port 0. You may refer to page 190 of the mega128 pdf file to get values that need to be written to the UCSRXX registers for proper baud rate setting. Hope this helps
Regards
Parthasaradhi Nayani
