byte mask negation
4 posts / 0 new
Hi
how to write fast this
PORTD     1 0 0 0 1 0 00 (8bit unsigned char)
NEGATION  ! 0 0 0 0 ! 00 (8bit unsigned char negation mask)
Result    0 0 0 0 1 1 00
is it possible use any special ASM instruction or I have to use slow for/cycle statement mask compare and set result byte ?
I am not sure if XOR is best solution in this case ?
-Pantelis
Professor of Applied Murphology, University of W.T.F.Justhappened.
I think you'll find the xor is the common solution.
Looks like problem is possible solve with XOR
I was not sure if is the only solution
I am trying develop GSM alarm with NC/NO/C
inputs and need have internal single logic alarm=log1 in variable som from this reason I am inverting some pins depends on NC/NO
