atmega8 watchdog and timers problem
8 posts / 0 new
Hi all ,
I've got some problems dealing with ATMEGA8
I haven't had this kind of problems with ATMEGA16,32,64,128 and 1280
Watcdog timer & TIM0_Delay(100) & TIM1_Delay(100) don't work
IDE : Codevision 2.04 , Crystal 16M , fUSEbITS on External Crystal
What's the problem ?
Why post in the OffTopic ?
Moved to general AVR forum.
Include .prj file so I can look at project settings and compiler configurations.
It all starts with a mental vision.
Here is the project :
When I compile the project, warnings suggest TIMO_Delay and TIM1_Delay are not linked. The way you have written these functions, they block other foreground activity. It is best to check for the correct time count, if not continue processing main events. I suggest you rethink the means of generating the delays.
I often like using the OCRx not overflow, since the next time can be += to the OCRx and does not result in cumulative error.
I commneted both of them cause non of them works .
But as I said I haven't had this problem with other micros . Don't you know what's the problem ?
And what about watchdog timer ?
You need to feed the watchdog periodically . How do you do that with code that blocks main activity while waiting in endless loop for ISR to count? I have used Mega8 in the distant past, in a few products without problems. Not related to that. Might be how you handle shared variables, and or handling of 16 bit control registers.
Start small. Verify your work, then add and verify again. You will learn how things work together, and develop a strategy for real-time programming. Simple is elegance, strive for that.
Don't give up. Just take a few steps back, and try again.
Thanks KitCarlson
