AtTiny13 running really slow
30 posts / 0 new
Hi guys
I have a small problem (irony)
I've programmed a tiny13 uC, and selected Div. by 8 OFF and the int. osc. 9.6 MHz
But the uC is running way below 1 MHz (guess as highest ISP speed is 127kHz before failing at 250kHz)
I'm using AVR studio 5 if it matters ?
and using the tiny13 for PWM.. but right now its blinking on and off every 3-5 sec. :-/
uC's: Atmega16, 32, 64, 128 and Attiny13
Lang.: C
Interests: Small scale robots AND sensor monitoring system
I'm using the Timer Overflow interrupt for PWM and prescaling 1024 times
Lang.: C
Show code.
Show dump of reading out the clock selection fuses.
#include
#include
#include
#include
uint8_t r_value = 0;
uint8_t g_value = 60;
uint8_t b_value = 0;
uint8_t pwm_counter = 0;
uint8_t color_state = 0;
uint16_t button_delay = 0;
ISR(TIM0_OVF_vect)		//Timer int for LEDs
	if(g_value <= pwm_counter)
		(PORTB &= ~0x01);
		(PORTB |= 0x01);
	if(r_value <= pwm_counter)
		(PORTB &= ~0x02);
		(PORTB |= 0x02);
	if(b_value <= pwm_counter)
		(PORTB &= ~0x04);
		(PORTB |= 0x04);
	if(pwm_counter == 255)
		pwm_counter = 0;
		pwm_counter++;
void init(void)
	/////////////PORT_SETUP/////////////DDRn > 0 input|1 output| PORTn > 0 low|1 high|
//	  DDRA  = 0x00;
//    PORTA = 0x00;
	DDRB  = 0x07;		//
    PORTB = 0x18;		//
//    DDRC  = 0x00;
//    PORTC = 0x00;
//    DDRD  = 0x00;		//
//    PORTD = 0x00;
	MCUCR = (0<<PUD);		//Pull-Up enable
	/////////////Timer_Setup////////////
	TCCR0A = (0<<WGM01);							//Normal mode
	TCCR0B = (0<<CS02)|(0<<CS01)|(1<<CS00);		//clk/??
	TIMSK0 = (1<<TOIE0);							//Overflow int0
	sei();
	//ADC_Init();
	init();
		uint8_t r_value = 128;
		uint8_t g_value = 128;
		uint8_t b_value = 128;
SELFPRGEN = [ ]
DWEN = [ ]
BODLEVEL = DISABLED
RSTDISBL = [ ]
SPIEN = [X]
EESAVE = [ ]
WDTON = [ ]
CKDIV8 = [ ]
SUT_CKSEL = INTRCOSC_9MHZ6_14CK_4MS
HIGH = 0xFF (valid)
LOW = 0x76 (valid)
Lang.: C
MCUCR = (0<<PUD);
This statement (and the others like it) do not do what you think. This sets ALL bits of MCUCR to 0, not just the PUD bit. Use this instead:
MCUCR &= ~(1<<PUD);
These statements do nothing. The variables defined here are NOT the same as the variables defined globally, they are separate local variables. The golbal versions (the ones being seen in the ISR) are never changed. Remove the uint8_t from these statements. Also, any variable that is used both inside and outside of an ISR must be declared "volatile" or else any local changes in main may not be seen in the ISR.
      pwm_counter = 0;
      pwm_counter++;
No real need to do this. pwm_counter is an 8 bit value. If you increment it when the value is 255, it will automatically roll over to 0.
Steve A.
You have not written TCNT0 with any value, nor do you re-load it, so that delay will be at it's absolute maximum value (256),
giving you a default period rather than one that you planned. I am not sure if that is what you intended. I always prefer to use CTC mode, where no reloading is required.
Lee -.-
Koshchi: Thanks alot ! :)
I have always used MCUCR = (1<<PUD); to set a bit.. is that still correct ? just the clearing of bits theres wrong ?
and the uint8_t is a typo :/
but forgot everything about the volatile declaration.
I'll try the stuff when I get home
LDEVRIES:
I'm aware of this, and just using the overflow interrupt
Lang.: C
No. It will set the bit, and clear all other bits. You should use
MCUCR |= (1<<PUD);
okay, so setting bits is
MCUCR |= (1<<Bit1)|(1<<Bit2)|(1<<Bit3);
and clearing is
MCUCR &= ~(1<<Bit1)|(1<<Bit2)|(1<<Bit3);
correct ?
Lang.: C
and clearing is
correct ?
No. You are only negating the mask for Bit1. You want to combine (or) the bitmasks first, and then negate that combined result. You need another set of parenthesis.
Okay :)
MCUCR &= ~((1<<Bit1)|(1<<Bit2)|(1<<Bit3));
Lang.: C
Whenever in doubt on this stuff, go over to the Tutorials forum and locate the piece on "Bit manipulation".
I actually have that one as a bookmark :D
just didn't relate it to setting up my bits :)
but thanks alot, looking forward to try the hints on my tiny13 and see if it helps with my problem
Lang.: C
You are not prescaling your timer clock. CS02 bit should also set to 1(for a prescale value of 1024).
This is weird because even if you run with 128 KHz internal oscillator and timer prescale of 1024 and pwm counter maximum value to be 255, you LED should be blinking for every one second.
-Krishna Balan S
"Heroes are ordinary people with extraordinary commitment"
I change the CS02 bit to zero trying to locate my problem, forgot to change it back :(
The other thing... that's what I thought, so I'm really confused.. but going to rewrite the program from scratch and see if it starts working then
Lang.: C
It is more educational to debug your existing program. What makes you think that you won't have a bug in your "from scratch" program.
OK on just using overflow. Try using CTC! It is easy & very precise.
Lee -.-
but is that usefull when I'm only using the interrupt as a timebase for my pwm ?
Lang.: C
I have a differing opinion. If B4Me starts from scratch, and then uses the "small steps" approach, testing incrementally and continuously, he will probably:
i) Get a working program within reasonable time, and
ii) Learn a very rewarding way to work on software development, and perhaps
iii) See where he went wrong the first time.
He could of-course also do something similar with his existing code: Cutting away pieces of functionality until it starts working again, and then learn where he went wrong.
Just as I held the opinion "both" in the "top-down or bottom-up?" debate a few months ago, I hold the opinion "both" here too. The golden trick re software development isn't to have one working method, but to have several and (the really difficult part) master when to use one or the other and understanding what/when they contribute to progress.
I did combine the ways :)
rewrote and reworked my old code...
the biggest mistake was that I were missing the "volatile" statement ! :/
but is it just my code thats slow... or does it makes sense that with
Osc = 9.6 MHz
prescaler at 256
and using normal mode on the timer
and a byte as my PWM count
I can see the off-time with the naked eye using 128 as my set value (50% duty cycle) ?
Lang.: C
I am probably of the same opinion, however I find that the small steps approach is not favoured with "y" geners. They want their code now and they want it running now.
My emphasis was on debugging it by, systematically breaking it down and debug it and then fix it(probably by patching out code until it is simplified). Debugging is a very important skills as we will always have bugs!. However I should also say, that the "y" gener's don't like debugging as it is time consuming and does not help in getting their code running "now".
However as at this time, they are smarter than we are, they should be allowed to quickly do it their own way, before they become as dumb as we are! :)
Lee -.-
I have noticed much the same as LDEVRIES, though I might attribute a slightly different cause than "impatience". I have worked with a number of EE grad students, age range early 20s to late 20s. A common, though hardly universal trait seems to be difficulty or reluctance to think through things in a logical, sequential manner, associating cause and effect. Or, using available tools to investigate in a logical manner.
Here is a recent example. The output of a 78L05 was lower than it should have been. What could cause it to be low?
Current limit? No evidence of that because it was quite cool and current required to limit would have gotten it warm.
Thermal limit? No, again, because it was quite cool.
Input voltage? It was large enough by a good margin, so no.
So, what could it be? I dunno.
Have you looked at the output with a scope? No.
Duuh! Its oscillating! Why? Inspection reveals that the pad on the ground side of the output cap is not connected to ground plane. Bit of solder - done.
I do not suggest that this is the case with B4Me. Instead, it is simply an unjustified, over-broad generalization. For, what ever it is worth.
Yes, it is a very broad brush generalization.
I hope Dean does not take my comments to heart and "out" me! :)
Lee -.-
I can make sure its not the same with me :)
I have a former education as electronic technician and right now halfway through my master in Mechatronics Engineering (with embedded as specialty)
But could we stick to my latest question buddys ? :)
I fixed my code, the biggest problem was the missing "volatile" statement, and thanks a lot for that note, cause It's some time since I last programmed on my AVR's :( (stupid school, stealing all my precious time)
The weird thing in my opinion now is:
9.6MHz clock / 256 prescaler / 256 pwm ticks (one byte)
that gives a switch frequency of
146.48 Hz or period time of 0.00683 s
so why can I see flickering here ?
should be impossible right ?
So is the problem that my code inside the interrupt is to big ?
Lang.: C
I love stereotypes. I for one am part of gen y and I do prefer the small steps approach and enjoy debugging.
You should not be able to see flickering if refresh is > 25-30 Hz.
I would have thought so!
It does not look as if it is that long, but its is preferable to make interrupts really small & fast ... Ie. one statements is all that is required to set a flag and then do the main processing in your main loop where you have oodles of time. Somewhere in the main loop, toggle a pin, so that you can measure the loop processing time with a CRO.
Perhaps post your code again so that we can see what it looks like now that you have made some changes.
Not really, but it is a nice way to do it, if you ever want an accurate time which cannot be achieved by counter overflow( which is what happens 99.6% of the time). I prefer to teach you have to fish, rather than feeding you a fish! :)
Lee -.-
I'll do that when I come home from work :)
Sometimes I get the idea of that I'm making really bad coding :-/ making big interrupt codes instead of flag's and so...
Lang.: C
Do the simplest test for verifying the AVR clock:
Write the "1 second blinky", and run it (sketchy, not at my AVR dev machine):
#define F_CPU 9600000UL
#include
   DDRB = 0x01;      // LED pin is an output
   while (1)
      _delay_ms(500);
      PORTB ^= 0x01; // Toggle LED
   return 1;
(Adjust the DDRB and PORTB manipulations to fit where your LLED is wired up.
If the led isn't blinking with a frequency of 1 Hz then your AVR is not running at 9.6 MHz.
I'd still like to see a proper screen dump of the fuses read out from the AVR.
Currently working code, with prescalling value at 8 !
#include
#include
#include
#include
volatile uint8_t r_value = 0;
volatile uint8_t g_value = 0;
volatile uint8_t b_value = 0;
volatile uint8_t new_r_value = 0;
volatile uint8_t new_g_value = 0;
volatile uint8_t new_b_value = 0;
volatile uint8_t pwm_counter = 0;
volatile uint8_t intensity = 1;
volatile uint16_t button_delay = 0;
		(PORTB &= ~0x08);
		(PORTB |= 0x08);
		(PORTB &= ~0x04);
		(PORTB |= 0x04);
		(PORTB &= ~0x10);
		(PORTB |= 0x10);
		if(r_value != new_r_value)
			if(r_value < new_r_value)
				r_value++;
				r_value--;
		if(g_value != new_g_value)
			if(g_value < new_g_value)
				g_value++;
				g_value--;
		if(b_value != new_b_value)
			if(b_value < new_b_value)
				b_value++;
				b_value--;
	if(button_delay < 25000)		//cycles since last button was pressed
		button_delay++;
	pwm_counter++;
void init(void)
//	  DDRA  = 0x00;
//    PORTA = 0x00;
	DDRB  = 0x1c;		//
	PORTB = 0x03;		//
//    DDRC  = 0x00;
//    PORTC = 0x00;
//    DDRD  = 0x00;		//
//    PORTD = 0x00;
	//MCUCR = (0<<PUD);		//Pull-Up enable
	TCCR0A &= ~(1<<WGM01);				//clear bits	//Normal mode
	TCCR0B |= (1<<CS00);				//set bits		//clk/8
	TIMSK0 |= (1<<TOIE0);								//Overflow int0
	sei();												//enable interupts
	init();
		if ( ( PINB & 0x01 ) == 0 && button_delay == 25000)
			button_delay = 0;
			if(color_state == 7)
				color_state = 0;
				color_state++;
			if ( ( PINB & 0x02 ) == 0 && button_delay >= 5000)
				button_delay = 0;
				if(intensity == 25)
					intensity = 1;
					intensity++;
		switch(color_state)
			case 0:
			new_r_value = 255/intensity;
			new_g_value = 255/intensity;
			new_b_value = 255/intensity;
			break;
			case 1:
			new_g_value = 0;
			new_b_value = 0;
			break;
			case 2:
			new_b_value = 0;
			break;
			case 3:
			new_r_value = 0;
			new_b_value = 0;
			break;
			case 4:
			new_r_value = 0;
			break;
			case 5:
			new_r_value = 0;
			new_g_value = 0;
			break;
			case 6:
			new_g_value = 0;
			break;
			case 7:
			new_r_value = 10/intensity;
			new_g_value = 10/intensity;
			new_b_value = 10/intensity;
			break;
			default:
			break;
Lang.: C
The
       button_delay++;
should not be in your ISR. It will slow your controller down.
Lee -.-
its just an increment with a if statement before ? where else then ?
Lang.: C
