I need CAREL proprietary protocol specifications...
I had write to Carel company, but without any answer.
No help from Google either.
Can anyone have some usefull links to documents?
Thank you.
Thank you.
Serial connection
The entire range of (carel)ir33 models has an RS485 serial port for connection to
supervisor or telemaintenance systems using a two wire plus shielded cable via a
serial network.
Hi Kas!
I have Rittal DK 3124.200 controller which have Carel procol embedded. I developing Carel protocol to MODBUS convertor, but I have nothing about Carel even in Rittal documentation.
(I expect answer from Rittal technical support, but main engineer is on vacation for two weeks. To long to wait, even positive result is not shure)
9.1.2 Phase 2, semi-automatic assignment of the addresses
At this point, the controllers to be included in the network must be added.
The program runs the automatic address assignment procedure, sending the
following command in the network;
Where
= 0 so that the command is received by all the controllers.
This is performed only by the controller in address assignment status, and when the
command is received, the unit:
• saves the new serial address,
• sends the response packet to the PC,
• displays the address received;
• qexits the address assignment procedure.
The command, received from an instrument with
<> 0, assigns the new
value contained in
for the serial address.
The response to the PC is the same as the request for the software version <‘?’>:
<‘V’> [ ]
I'm not shure. Have read whole document and see.
Please, send to PM.
Thank you Kas !
there were some problems with mails, see PM. Shall DropBox be an option? (2Gb limit)
Hello,there were some problems with mails, see PM. Shall DropBox be an option? (2Gb limit)
