Problems using RTC
11 posts / 0 new
I have an xmega192A3 with a 32.768kHz crystal on the TOSC pins. All i'm trying to do is get a 1Hz overflow interrupt.
My code:
	// real time clock configuration
	sysclk_enable_module(SYSCLK_PORT_GEN, SYSCLK_RTC);
	//Wait until RTC is stable
	CLK.RTCCTRL = CLK_RTCSRC_TOSC_gc | CLK_RTCEN_bm;
	//CLK.RTCCTRL = CLK_RTCSRC_RCOSC_gc | CLK_RTCEN_bm; // this works
	while (RTC.STATUS & RTC_SYNCBUSY_bm);
	RTC.PER = 1023;
	RTC.CNT = 0;
	RTC.COMP = 0;
	/* Since overflow interrupt is needed all the time we limit sleep to
	 * power-save.
	sleepmgr_lock_mode(SLEEPMGR_PSAVE);
	RTC.INTCTRL = RTC_OVFINTLVL_LO_gc;
	RTC.CTRL = RTC_PRESCALER_DIV1_gc;
// RTC timer overflow
ISR(RTC_OVF_vect)
	LED_PORT.OUTTGL = LED1;
This works fine for the internal oscillator, but the external crystal fails.
Any ideas?
Do you have a scope to verify that it's oscillating ? You have to enable XOSCEN and XOSCSEL[3:0], may be others. Either the XTAL's not working at the pin, you're missing some config. bits or both .
2) WinAvr 20100110
A) Avr Dragon ver. 1
B) Avr MKII ISP, 2009 model
C) MKII JTAGICE ver. 1
Solder the crystal directly onto the TOSC pins.
Why is the RTC.COMP = 0? Shouldn't it be 1 count higher than the counter?
There's no sign of life on the TOSC pins at all.
If i truly have to use XOSCEN and XOSCSEL, then that's really bad, because that would mean that you can't use an RTC crystal and a regular crystal at the same time. Why would you have separate pins for XOSC and TOSC if they are mutually exclusive?
That value is pretty irrelevant since i'm only enabling the overflow interrupt.
You're right, I took a closer look at those and they do set system ext. clk source. Since it's not oscillating, it looks like an issue with PCB in that area or the XTAL / caps. Can you show your PCB layout for this osc. and the 3 part specs ?
2) WinAvr 20100110
crystal is:
crystal @ farnell
C41 and C44 are 22pF 0603 caps
the pcb is 4 layers, with the layer just below being GND plane.
Ext. oscillator circuits can be touchey by component value, PCB cleaness/ layout. What are you using for system clk ? Check out AVR042 section 5 here :
http://www.atmel.com/dyn/product...
Xtal d.sht. states 12.5 pF, that may mean you have to use caps in that range and NOT 22pF. For TOSC circuits, the caps are usually lower value than for ext. system clk. circuits ( where 22pF are doable ) . That might be the issue. Try that suggestion about using a short 2-lead watch XTAL and solder firectly to the pins ( remove the smd XTAl...if you can :cry: ) though and smaller caps .
2) WinAvr 20100110
AVR4100: Selecting and testing 32kHz crystal oscillators for Atmel AVR microcontrollers
http://atmel.com/dyn/resources/prod_documents/doc8333.pdf
Go to pages 18 and 19.
I switched the caps to 12pF, still didn't work.
Then i switched the crystal to a CITIZEN AMERICA
CM130 32.768KDZF-UT, and now it works.
Thanks for the help
Works with the 12 pF caps ? What 's the name of the non-working XTAL so we can avoid it !!
2) WinAvr 20100110
It may or may not need the capacitors: AVR1012: XMEGA A Schematic Checklist
Pages 8 and 9.
