Surface mount right angle headers
6 posts / 0 new
Was wondering if I could find this type of connector in a surface mount package?
http://search.digikey.com/scripts/dksearch/dksus.dll?pname&WT.z_cid=ref_octopart_dkc_buynow&site=us&lang=en&name=A1927-ND
I've found surface mount right angle headers of course but none with the half shroud like this has.
http://www.samtec.com/ProductInf...
Only ones I've been able to find. Can usually get a few samples in 2 or 3 days. Actual orders typically have 5-10 day lead times.
Edit: despite the picture, they do actually come in right angle variants.
Science is not consensus. Science is numbers.
If you are specifically looking for the AMP "MTA" series as your link implies , have you been to the AMP website?
the half shroud is the "locking friction ramp" specifically for the MTA series and the two cutouts on the end are the alignment keys for the mating MTA connector.
http://www.te.com/catalog/bin/TE.Connect?C=10254&M=FEAT&P=176363,174068&U=&BML=19089&LG=1
Yeah I checked their website but couldn't seem to find anything really.
Samtec is the only company I have been able to find, after a pretty extensive search, that have a SMT r/a semi-shrouded connector -- even if it isn't the same series as your original request.
Yeah I had found these before: http://www.gradconn.com/surface-... which are similar to the ones you found but was looking if there were any like the AMP ones.
