Trying to use 100% of flash
14 posts / 0 new
ATXMEGA32A4 Flash: 32KB + 4KB for Boot
I have the bootloader working, it uses around 3KB. My main application is very large and doesn't fit with the bootloader, so I'm trying to fill the remaining space in the bootloader with some constant tables.
The problem is that when the bootloader gets above 4036 bytes, I get an error when I try to program:
The contents of the objectfile exceeds the maximum program memory of the device
Why? I assume there might be gaps when the linker generates the HEX file. How do I get closer to 4096 bytes?
This is how the HEX file looks like when exceeding 4036 bytes, the first part seems to be in sequence, but at the end, there is something else:
:108000000C94CA420C94E0420C94E0420C94E0427E
:108010000C94E0420C94E0420C94E0420C94E04258
:108020000C94E0420C94E0420C94E0420C94E04248
:108FA00008958091CF0187FDFCCF80E3E0ECF1E0F4
:108FB0008287EBECF1E021E030E088ED90E084BFC7
:088FC00020830895F894FFCF0F
:108FC800EE27FF2719BEDC0143E24093CA0150E8AF
:108FD8002DE90D901D9020933400E89532965A950E
:108FE800C1F711240895FC014093CA012DE920938B
:0A8FF8003400E89511243BBF0895F2
:040000030000800079
:00000001FF
And a second question, once I get the bootloader done, is there a way I can generate an error if the main application exceeds 32KB?
The bootloader code is here if anyone wants to take a look.
You are exceding the the max limit of bootloader.
Also you have to be sure with bootlock bits weather it allows LPM from application flash to read content of boot flash.
This is intel hex format. read following link to debug it.
http://www.scienceprog.com/shelling-the-intel-8-bit-hex-file-format/
I think you will get unexpected behaviour
Since your question was only XMEGA related, you should ask the moderator to move it into the XMEGA forum.
Peter
Let me rephrase my question. Why does the compiler report 4036 bytes used if the device is already full? Shouldn't "full" mean 4096 bytes?
I dont suppose its ignoring the bootloader interrupt vector table?
There's a lot more than 60 bytes in a ATXMEGA32A4 vector table.
Ah well, it was bit of a guess.
Still getting my head from mega to Xmega.
I am back working on the bootloader. Again, I want to maximize what I can fit in the bootloader. I am checking the assembly listing and I see the vector table:
00008000 <__vectors>:
8000: 0c 94 bc 41 jmp 0x8378 ; 0x8378 <__ctors_end>
8004: 0c 94 d2 41 jmp 0x83a4 ; 0x83a4 <__bad_interrupt>
8008: 0c 94 d2 41 jmp 0x83a4 ; 0x83a4 <__bad_interrupt>
8170: 0c 94 d2 41 jmp 0x83a4 ; 0x83a4 <__bad_interrupt>
8174: 0c 94 d2 41 jmp 0x83a4 ; 0x83a4 <__bad_interrupt>
My bootloader will not use interrupts, how can I use this section for my own use (code or data)?
edit: currently reading the bootloader FAQ.
Read this:
Smallest bootloader?
Note in particular my techniques for ditching the CRT (including the vector table) but keeping a (nearly) all C solution.
Cliff
(-nostartfiles and -nodefaultlibs are your friends)
EasyBootXAvr takes around 700bytes. CRC and serial number.
You could put a constant in C on the location the bootloader will be and then overwrite the booloader in the hex file. I am not a C guy, I just guess.
The problem is you can not lock the boot area for writing if you want to update your application residing in the boot area. This would expose the bootloader to unintended writings.
George.
What tool are you using to get this "4036 bytes" number? Some tools won't show all of the sections that actually have to be loaded into flash for everything to work. (trivial example, the flash used is the sum of text and data segments reported by avr-size.)
avr-gcc under AVR Studio.
You mean "avr-size" in AS5? (or AS4?)
AVR Studio 4
