hi guys. I am spending me holidays with my stk500. my girlfriend is still waiting. jiji.
At the begining is was worthy but now that I am trying to use an sd card is getting very frustrating. I got stuck already 5 days ago...... I am not able to compile any correct file. The only codes I could get without errors were bigger that what my atmega16 can handle.
is the atmega16 getting weak for this stuff?
Do I need to go for a bigger microcontroller like atmega 32...?(I dont have it now)
my only target is to create and .txt or csv and write a variable into it(a data logger), and I would quite.
I have read about elmchan librarys the full and the petit. the full library seems to be too big for my humbre atmega16. the petit library does not create files, it just allows you to open existing files.
I also read some threats here in avrfreaks where clawson showed to one guy how to create a txt but it was with the full elchan library wich is too big for my atmega16.
I found dataloggers for bigger atmegas and also some projects for sound for atinys and , but I was trying to succeed with a more simpler thing.
can someone share a proven code to start with that my atmega16 can handle? Just for this trial. The next attempt seems to be with a bigger atmega the next holidays.
Thankyou guys.
