I'm unable to access either link right now. It seems my mobile android browser I us here at at remote cabin or the flaky gprs connection don't cut it. Will check it out next week at home.
http://news.nationalgeographic.c...
Uploaded a new toolchain .deb package to : http://www.wrightflyer.co.uk/avr...
It's based on the Atmel AS5 patches , gcc-4.5-1 and also include avr-libc-1.7.1 and the new avrdude-5.11
Note ... Atmel calls the patches for AS5-beta but these are the ones they released , when they released their own AS5 toolchain.
The files uploaded are :
avr-gcc-4.5.1-AS5-avrfreaks-11-sep-2011-u10.04.i386.txt
avr-gcc-4.5.1-AS5-avrfreaks-11-sep-2011-u10.04.i386.deb
avr-gcc-4.5.1-AS5-avrfreaks-11-sep-2011-u10.04.x64.txt
avr-gcc-4.5.1-AS5-avrfreaks-11-sep-2011-u10.04.x64.deb
They have only been slightly tested , use/test on your own risk.
EW has requested that i do not release the buildscripts , as he is working on integrating the patches in a better way.
All sources are accessible as per GNU.
Url to AS5 patches are somewhere in this thread.
Please make dure that the directory /usr/local/avr is empty or non-existant before installing the package.
Ie.: Remove the old .deb package or .....
See here for some possible bugs in AS5 , that would also be present in this toolchain (sorry ... I didn't know).
The AS5 toolchain simply looks to "sick"
I'll ask clawson to remove the packages from wrightflyer
/Bingo
Bingo,
thanks for the work, appreciated !
It's based on the old "Trusty" avr-gcc-4-3-4 , avr-libc-1.7.1 , avr-insight-6.8-1a and the new avrdude-5.11
I switched the naming-convention , in hope of a better grouping on wrightflyer.
avr-gcc-4.3.4-avrfreaks-2011-sep-12-u10.04.i386.deb
avr-gcc-4.3.4-avrfreaks-2011-sep-12-u10.04.i386.txt
avr-gcc-4.3.4-avrfreaks-2011-sep-12-u10.04.x64.deb
avr-gcc-4.3.4-avrfreaks-2011-sep-12-u10.04.x64.txt
Make sure /usr/local/avr is empty/"non existant" before install
Edit:
The avr-gcc-4.3.4-avrfreaks-2011-sep-12 versions
have been removed , due to a serious bug in avrdude 5.11.
Get the avr-gcc-4.3.4-avrfreaks-2011-sep-20 versions
/Bingo
It's based on the old "Trusty" avr-gcc-4-3-4 , avr-libc-1.7.1 , avr-insight-6.8-1a , avarice-2.11 and the new avrdude-5.11.1 (Bugfixed)
avr-gcc-4.3.4-avrfreaks-2011-sep-20-u10.04.i386.deb
avr-gcc-4.3.4-avrfreaks-2011-sep-20-u10.04.i386.txt
avr-gcc-4.3.4-avrfreaks-2011-sep-20-u10.04.x64.deb
avr-gcc-4.3.4-avrfreaks-2011-sep-20-u10.04.x64.txt
Comments should go here:
/Bingo
Do any of the Atmel toolchain "improvements" or support for new devices have any chance of seeing the light of day in here (after bug smashing)?
If the Atmel toolchain "improvements" , finds it way into the FreeBSD repos , then yes.
It seems a bit like it is going to function this way.
Atmel toolchain "improvements" from (Atmel AS) is being merged into the upstream avr-gcc
Eric/SprinterSB and others are doing lots of other fixes to upstream.
Then ...
1: Eric does WinAVR , based on upstream & "maybe other magic"
3: Eric & Jörg coordinates
4: Jöorg does FreeBSD
5: I do FreeBSD -> avr-freaks buildscript
So Atmel/Eric/Jörg/SprinterSB does all the hard work :-)
I just make it build on linux
/Bingo
If the Atmel toolchain "improvements" , finds it way into the FreeBSD repos , then yes.It seems a bit like it is going to function this way.
Then ...
5: I do FreeBSD -> avr-freaks buildscriptSo Atmel/Eric/Jörg/SprinterSB does all the hard work :-)
/Bingo
But I thought that WinAvr was dead (hasn't been a new build in over a year) and that Atmel's tool set was the replacement.
AVR Toolchain is a half-arsed attempt by an Atmel off-shore team to try and replicate WinAVR - they failed miserably. There's serious faults like large flash devices not having ELPM in their .data loop and so on. It also misses many of the "goodies" that make WinAVR such a complete package. In no way can it be considered a "replacement" for WinAVR.
Most of us stick with WinAVR20100110 and look forward to WinAVR2011xxxx (or perhaps WinAVR2012xxxx?)
YEAH! I'm also stuck with winavr2010 (though my system has been polluted with the Atmel toolset via installing the latest AS5 I still have winavr in my path.
Be warned I've noticed that AS4 has a nasty habit of spotting "toolchain" in preference to WinAVR so always check Project-Configuration Options-Custom Options and make sure it's always set to "WinAVR" and hasn't been polluted with "Toolchain" if that's installed.
Hello. I am having some problems with the most recent build scripts. When running buildinsight.sh I get the following:
insight-6.8-1/sim/h8300/ChangeLog insight-6.8-1/sim/h8300/compile.c insight-6.8-1/libtool.m4 ./buildinsight.sh: line 84: cd: insight-6.8-1a: No such file or directory (./buildinsight.sh) patching Insight/GDB source Patching with /home/swinchen/Builds/build-avr-gcc-4.3.4-binutils-2.20-libc-1.7.1-insight6.8-1a-dude-5.11.1-insight-patch/make-avr-gcc/patches/insight-6.8-1a/patch-atmega256x-gdb can't find file to patch at input line 3 Perhaps you used the wrong -p or --strip option? The text leading up to this was: -------------------------- |--- gdb/avr-tdep.c.orig 2008-01-11 14:19:59.000000000 +0100 |+++ gdb/avr-tdep.c 2010-01-19 11:19:47.000000000 +0100 -------------------------- File to patch: Skip this patch? [y] Skipping patch. 3 out of 3 hunks ignored (./buildinsight.sh) gcc patching failed (0) [swinchen@rudder make-avr-gcc]$
When running buildavr-no-insight.sh I get the following:
gcc -DHAVE_CONFIG_H -I. -I../../../source/avarice-2.11/src -Wall -Wextra -g -O2 -MT gnu_getopt1.o -MD -MP -MF .deps/gnu_getopt1.Tpo -c -o gnu_getopt1.o ../../../source/avarice-2.11/src/gnu_getopt1.c mv -f .deps/gnu_getopt1.Tpo .deps/gnu_getopt1.Po g++ -g -O2 -o avarice crc16.o devdescr.o ioreg.o jtag2bp.o jtag2io.o jtag2misc.o jtag2prog.o jtag2run.o jtag2rw.o jtag2usb.o jtagbp.o jtaggeneric.o jtagio.o jtagmisc.o jtagprog.o jtagrun.o jtagrw.o main.o remote.o utils.o gnu_getopt.o gnu_getopt1.o -lusb -lbfd -liberty -lz /usr/lib/libbfd.a(plugin.o): In function `try_load_plugin': (.text+0x3c8): undefined reference to `dlopen' /usr/lib/libbfd.a(plugin.o): In function `try_load_plugin': (.text+0x3eb): undefined reference to `dlsym' /usr/lib/libbfd.a(plugin.o): In function `try_load_plugin': (.text+0x47b): undefined reference to `dlerror' collect2: ld returned 1 exit status make[2]: *** [avarice] Error 1 make[2]: Leaving directory `/home/swinchen/opt/bingo/build/avarice-2.11/src' make[1]: *** [all] Error 2 make[1]: Leaving directory `/home/swinchen/opt/bingo/build/avarice-2.11/src' make: *** [all-recursive] Error 1 Making install in scripts make[1]: Entering directory `/home/swinchen/opt/bingo/build/avarice-2.11/scripts' make[2]: Entering directory `/home/swinchen/opt/bingo/build/avarice-2.11/scripts' test -z "/home/swinchen/opt/bingo/bin" || /bin/mkdir -p "/home/swinchen/opt/bingo/bin" /bin/install -c ../../../source/avarice-2.11/scripts/start-avarice ../../../source/avarice-2.11/scripts/kill-avarice ice-gdb ../../../source/avarice-2.11/scripts/ice-insight '/home/swinchen/opt/bingo/bin' test -z "/home/swinchen/opt/bingo/share/avarice" || /bin/mkdir -p "/home/swinchen/opt/bingo/share/avarice" /bin/install -c -m 644 ../../../source/avarice-2.11/scripts/gdb-avarice-script '/home/swinchen/opt/bingo/share/avarice' make[2]: Leaving directory `/home/swinchen/opt/bingo/build/avarice-2.11/scripts' make[1]: Leaving directory `/home/swinchen/opt/bingo/build/avarice-2.11/scripts' Making install in src make[1]: Entering directory `/home/swinchen/opt/bingo/build/avarice-2.11/src' g++ -g -O2 -o avarice crc16.o devdescr.o ioreg.o jtag2bp.o jtag2io.o jtag2misc.o jtag2prog.o jtag2run.o jtag2rw.o jtag2usb.o jtagbp.o jtaggeneric.o jtagio.o jtagmisc.o jtagprog.o jtagrun.o jtagrw.o main.o remote.o utils.o gnu_getopt.o gnu_getopt1.o -lusb -lbfd -liberty -lz /usr/lib/libbfd.a(plugin.o): In function `try_load_plugin': (.text+0x3c8): undefined reference to `dlopen' /usr/lib/libbfd.a(plugin.o): In function `try_load_plugin': (.text+0x3eb): undefined reference to `dlsym' /usr/lib/libbfd.a(plugin.o): In function `try_load_plugin': (.text+0x47b): undefined reference to `dlerror' collect2: ld returned 1 exit status make[1]: *** [avarice] Error 1 make[1]: Leaving directory `/home/swinchen/opt/bingo/build/avarice-2.11/src' make: *** [install-recursive] Error 1 (./buildavr-no-insight.sh) avarice build failed
I fixed this error by changing the following line:
- ../../source/${avaricebase}/configure -v --prefix=$prefix + ../../source/${avaricebase}/configure -v --prefix=$prefix LIBS="-ldl"
This is being compiled on Arch Linux (up to date as of the writing of this message)
Sam
I beleive its in the readme , that the insight archive must be extracted
Diirectory renamed
And repacked with the correct name
I even think there is a script for that
The avarice error didnt show up on my ubuntu
But thanx for reporting
Just to let people know, I took a look at the script to see how the build is done, easy enough, so I built the toolchains in cygwin (version 1.7.9(0.237/5/3)) and it seems to work fine.
I built binutils/gcc/avrlibc/avrdude only.
I will test some .lss against ones coming from a WinAVR compile.
Hi all,
Maybe I am wrong, but I was terrified when I found that clawson's .deb installs (an older version) of avr-gcc.
I installed the AVR package on Ubuntu 11.04. All working OK, I use it on a daily basis. And I can't do without.
But I want to have a go with the AVR32. So I downloaded the
avr32-gnu-toolchain-3.2.3.261-linux.any.x86.tar.gz
from Atmel. Unpacked it but found no instructions how to install this and how to use it.
So then I found the sticky part of this thread and tried clawson's .deb package. It could have been so nice...
I'd expect things like avr32-gcc, avr32-as etc to get installed. But I found they have the same name as the 8-bit version. Is this "as intended", and can I get both AVR and AVR32 from the same GCC compiler? If that is the case, has anyone an example of an AVR32 makefile?
Thanks in advance,
Simon
This forum, Bingo's script and the .deb's on my website are ONLY for the 8bit avr-gcc, not avr32-gcc. Suggest you visit the AVR32 forums here for info about that.
Simon
@nlsgs
For AVR32 i'd suggest the Atmel toolchain
But i can't help out with usage. You'll have to go to the AVR32 section here (as Cliff suggested)
If you are brave , you could try out James Snyder's buildscript.
But note that he says "not been extensively tested"
https://github.com/jsnyder/avr32...
If you run into problems while patching mpfr :arrow:
build-avr-gcc-4.3.4-binutils-2.20-libc-1.7.1-insight6.8-1a-dude-5.11.1-insight-patch.zip has mpfr-3.0.1 in the package-versions file. The get-patches.sh script download the "mpfr-current" patches.
This two versions do not match anymore.
My fix was to change "mpft-current" to "mpfr-${mpfrver}" in get-patches.sh.
Then run buildavr-cleanup.sh and get-patches.sh again.
So it looks like the patch adding tn4313 support is:
http://distribute.atmel.no/tools...
TopAtmel AS toolchain buildscript
/Bingo
TopI know that 3 years ago Atmel was showing off AVR32 studio using eclipse. When they presented the whole audatorium moned as that eclipse was slow and buggy at the time. Thus I bet they went with visual studio to fix this problem.
However I was one of the ones that moned, and now I do all my development in eclipse as that it is almost functional. With that said it is nothing like visual studio was 5 years ago using whole tomato's plug-in. Specifically Whole Tomato's plug-in for visual studio was the most productive gain I ever got in programming.
However now that half our office uses Linux and I am personally about 80% windows 20% linux I will most likely stick with eclipse.
Trampas
TopI think that my question is a bit off topic, but here it goes.
I use both Windows and Linux(ubuntu), cant I just use the avr-gcc that is available in the repositories to compile code for avr's?
Or is it better to compile from scratch using the given script in the last page?
TopThe guys at Canonical are experts in package building and so on. They are not experts in AVR programming. So they'll tend to just pull the head of the GCC tree and build the AVR variant without necessary applying some of the vital patches that haven't yet made it upstream to the core GCC project. So repository versions can be "sporadic" at best (though I think 10.10 is getting quite good). You are far safer using the Bingo script because it encompasses the combined AVR knowledge of Eric, Joerg and Carsten. As you will have read in ti thread Bingo (Carsten) builds a .deb each time he modifies the script anyway and these are hosted on my website at:
www.wrightflyer.co.uk/avr-gcc/
These are perfect if you use Ubuntu as installation is nothing more than a "dpkg -i" command.
TopThanks for the fast and detailed information Clawson.
The avr-gcc in the repository must be really old, so I will use that .deb and try it.
This is the version of the avr-gcc from the repository, 2 years old :o
tiago@tiago-laptop:~$ avr-gcc --version
avr-gcc (GCC) 4.3.4
Copyright (C) 2008 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
TopThe .deb's on my site are 4.3.4 as well. If Atmel release a list of the patches for the avr-gcc in AS5 then I'm guessing Bingo will update the build script and put new .deb's on my site.
Cliff
TopThat is a history-writing that I do not agree with. I know for a fact that not everyone in the auditorium moaned.
As of January 15, 2018, Site fix-up work has begun! Now do your part and report any bugs or deficiencies here.
No guarantees, but if we don't report problems they won't get much of a chance to be fixed! Details/discussions at link given just above.
TopYupp :-)
/Bingo
TopIs this what's needed?:
http://distribute.atmel.no/tools/opensource/as5-beta/
TopI hate it when they name it beta :-(
I doubt i'm able to make anything this weekend.
Edit: By advice from EW i'm holding off the release until the patches has been cleaned up a bit.
I might release .deb's of the older AS toolchain , if people need t10 support.
/Bingo
Topnewbee here. Am I reading these last few messages correctly? The gnu toolchain does not support AVR32 yet.
TopBingo600:
I would like to use one of your build scripts (great work! by the way) and I want to build it all static.
I want to be able to upgrade operating systems (kubuntu) and not having to compile everything from scratch. Also, I would like to stick with the exact same versions, since I know my software is working fine with them, and avoid some new bugs that might come with recent releases.
So, I just need to copy the installation folder to my new operating system.
Another question: can I compile static on 64bits and use on it 32bits or vice-versa?
Thanks!
TopAVR32 GCC on Linux - There are some instructions on how to rebuild using Atmel's patches but I'd have to dig to find these; one cross-compile build suite has AVR32:
http://foss.doredevelopment.dk/wiki/Avr32-toolchain
Top++on this, just saved my build. archlinux x86_64
TopHi All
I was just wondering what the bottom line with development of the next version of WinAVR is and also with clawson's nice debian/ubuntu packages.
Will the next versions basically catch up with the AS5 toolchain. Will it also use the non VS2010 based back end programming and debugging stuff? Are you guys basically waiting for Atmel to properly release the source etc to this stuff before you can do your magic and create versions of them for the rest of us (I have zero intention of using AS5).
srg
TopThis will be toolchain releases only.
No editors or ides.
Just plain compiler
But i usually wait for Jorg to release the patches
For freebsd before updatilg the linux buildscript
/bingo
TopWhy should WinAVR include a Visual Studio-based IDE? Leave that to Atmel?
AFAIK the sources has been released, but I might have misunderstood what the Atmel folks have posted here at 'freaks.
Re debugging stuff, I don't think that Atmel will release any sources. It is proprietary stuff. What would be nice is if someone with potential, knowledge, budget and authority (i.e. paid by, or at least ratified by, Atmel) wrote a GDB driver for Atmels debugging hardware (or at least for "a modern subset", e.g. Dragin, JTAGICE mkII, JTAGICE mkIII and AVROne!), and relesed it as a binary for some popular GNU_Linux distros (Fedora, Debian/*buntu, ...).
The hardest thing going for an open-source, cross-platform AVR development solution is that the debugging protocols are proprietary.
TopI didn't mean that WinAVR should have an IDE or editor bundled with it at all, I just wondered about the current state of the current tools it has.
I don't want WinAVR to have a VS based IDE, that's why I loathe AS5.
I thought the back end was seperate from the VS based front end. I wondered if that back end would be repackaged in WinAVR etc for those that don't want to use AS5.
Otherwise I was just wondering what the current state of WinAVR is?
TopI am not part of "the team", but the current state seems to be that there is work planned or even on-going for a new release of WinAVR.
The core of this has always been a complete tool chain (compiler, linker and other binutils, avrlibc runtime library), and added to that values like AVRDude for programming AVRs, parts of debugging solutions (that I do not understand, like AVaRice), the excellent Mfile utility.
I would expect that this "core" will be very similar in the upcoming release.
It has also come with the Programmers Notepad editor, but you could just as well use your own favourite editor or IDE. A change here would not surprise me. Get me right, staying with PN would not surprise me either. Not would a WinAVRnext relese without any editor/IDE.
If "the team" actually has any clarifications, detailed plans or some such that can be shared at this time, I'm sure we'll see them when he passes by this thread.
TopI made the Ubuntu packages, based on the latest linux buildscript packages (from this thread), at that time.
Clawson was/is kind enough to provide hosting , as i can't do that.
I did offer to make a Ubuntu package of the "older AS" toolchain , but was asked to hold back on releasing an AS5 Toolchain , due to the state of the patches.
And as it a bit of work to make the Ubuntu package , and there was no response ... I never bothered.
The AS buildscript is here
/Bingo
TopWhat is the appropriate way to get an updated toolchain on linux and osx at this point?
TopFor OSX i guess you have to build it your self,
For Linux i'd do the same , but i think Atmel might have something for Linux.
/Bingo
TopI would be delightef if this is true. Do you hava any references to back it up ?
Markus
Tophttps://www.avrfreaks.net/index.p...
~~John
TWI C source code
TopThis is not about linux, but just a standalone version of the AVR-gcc for Windows provided by Atmel (standalone=without the Microsoft GUI). The sources/patches are included, so you can build a Lknux or MacOS version yourself.
For me this does not qualify as 'having something for Linux'.
Markus
TopThe second link was for linux.
http://www.atmel.com/dyn/product...
~~John
TWI C source code
Top[quote="atomicdog"
So I stand corrected.
Markus
Top
