A free test tool for RS232 and TCP IP socket
10 posts / 0 new
USR-TCP232-Test : serial to network debugging assistant: TCP / IP networks and serial debug debugging assistant
green and free software for you.
The key features [Software]:
1 serial port debugging and network debugging assistant assistant combined, especially for debugging network equipment.
2 support Chinese and English dual-language.
3 is minimized to stay in the lower right corner, do not take up the task bar position.
4 can store all the parameters set, the port number, baud rate, IP address etc, the next automatic load and save time.
Network Assistant features:
1 supports TCP and UDP protocols support broadcast mode TCP Server, TCP Client, UDP
2 supports ASCII / Hex send, send and receive data in hexadecimal and AscII between arbitrary code conversion, support for sending and displaying Chinese characters.
3 can automatically send parity bit, check to support a variety of formats.
4 support the interval to send, loop send, receive data can be stored as files, you can also import data from a file to send.
5. Wrap support to receive the results show
Serial debugging assistant features:
1 support the common 110-115200bps baud rate, port number, parity, data bits and stop bits can be set
2 up to 16 COM ports
3 can be in ASCII or hexadecimal data or receive or send any characters (including Chinese)
4 can be set to send automatically send cycle
5 supports an additional check function, and validation, accumulation and inversion parity, fixed value.
6 can receive data into the file, you can send data to the file input area.
7 Support to receive the results automatically wrap
Jinan USR Technology Co., Ltd. provid RS232 to networking products and solutions series modules, wired (WLAN) networking, wireless (WIFI) network, GPRS, 3G, etc. Welcome to visit htttp://en.usr.cn
RS232/RS485/TTL UART to Ethernet/WIFI/GPRS convert product
http://en.usr.cn
This looks an awful lot like spam but I think I'll leave it for the time being.
Moderator.
A good hunch I suspect. The link is unknown.
Lee -.-
Test and debug software: http://www.usr.cn/Uploads/Downlo...
zauberer, I'm not clicking on that link. What is it about?
About serial to network debugging assistant
It's an .exe file. Are you crazy? :? :)
This is direct link to OP debugging assistant
Moderator.
This is an useful software, and you are right, the link is for AD, you are right.
But is it ok for a good free software for you , only add a link?
Thanks for all the friends who has Reply my topic.
http://en.usr.cn
When you start spamming several threads with the same message then you are considered a spammer. I have deleted your other threads as spam and this one may follow shortly.
