Floating point intitialization errors
3 posts / 0 new
I am working with an atxmega256a3b. I am trying to initialize a floating point value to be true 0. My code looks like this
float DCM_Matrix[3][3]= {
1,0.0F,0.0F }
0.0F,1,0.0F }
0.0F,0.0F,1 }
The values in the matrix are being set to a decimal values that are very close to 0 but not exactly. for instance, DCM_Matrix[0][1] = -0.00060707104 and DCM_Matirix[0][2] 0.00060707104
However, it has no problem initializing the 1 values to exactly 1.
Is there some error occurring that causes these float values to not be set to 0?
Does anyone now how I can declare the matrix so that the values will be true 0?
    1,0.0F,0.0F }
    0.0F,1,0.0F  }
    0.0F,0.0F,1 }
Why not initialise with 0 rather than 0.0F ?
The Compiler knows that every expression is a float anyway.
Are you really sure about those f-p values? That is considerably greater than one significant bit in the mantissa.
Which C compiler? I just tried this with avr-gcc in AVR Studio 4 and got exactly the expected result. In SRAM you can see the 0x3F800000 values representing 1.0 and 0x00000000 representing 0.0 (this is IEEE754 format):
