LCR meter 4070 modification
14 posts / 0 new
OK. So I rolled the dice on getting a cheap-o LCR meter. It's a model 4070 that can be found on eBay and other places. It's a neat little meter, but the ranges for inductance go from 20H down to 20mH. 20H. Really? When was the last time you worked with a 20H inductor. A lot of the stuff I'm doing now use inductors from 1uH (TI TPS63020, 2.4 MHz) to a few mHs.
So... 2 questions.
1 - Is there a decent LCR/RLC meter out there that can measure down to the uH range that won't break the bank.
2 - How does an LCR meter work? I could maybe change some component values to change the range from 20H - 20mH to 20mH - 20uH.
I figured I'd ask here first.
EDIT: The test frequency is 100Hz. If I could change the test frequency, to 1000Hz or 10,000Hz would that make a measured inductor appear larger or smaller? Could I get a 1 micro-Henry inductor to appear as though it were a 1 milli-Henry inductor? Thus lowering the overall range?
Jim M., Rank amateur AVR guy.
XL = 2PIfL where:
XL = reactance in ohms ()
f = frequency in hertz (Hz)
L = inductance in henrys (H)
http://sites.google.com/site/vk3...
for a nice one-chip (PIC) LC meter, that works fine for uH - mH ranges (I built a couple)
Xantor wrote:
XL = 2PIfL where:
Nice link to the PIC project.
So to keep reactance the same, a smaller inductor would require a higher frequency. I'll see what I can come up with. I'd rather just mod the existing meter than build my own.
Jimmy,
Our fellow 'Freak "Plons" (Nard Awater) has a very nice design called "Elmcie" http://www.aplomb.nl/TechStuff/E...
Worth a read if nothing else ... but also worth building.
Cheers,
Ross
20H inductors are out there... The secondary coil on a transformer in a disposable camera flash circuit is typically a few henries.
Not bad, jayjay. Thanks.
I also have the peak one that JayJay1974 has; I really like it.
Alan
I have an Extech 380193. Dave (EEVBlog) made a review.
Felipe Maimon
Thanks, guys. All good stuff. I'm going to start saving my pennies for a decent LCR.
Keithley 3322 LCZ when needed
I have a Beckman LM22A portable LCR meter. 3.5 digit with the lowest full scale inductance being 200 uH, highest is 200 H.
Tom Pappano
Tulsa, Oklahoma
Thanks. Another pretty reasonable LCR.
