NMEA
4 posts / 0 new
there seems to be lots of messages about parsing NMEA sentences from a GPS module; that's fine and looks straightforward.
But some of those sentences include 'reached waypoint information' or duplicate each other.
Hopefully, there is a standard that you can use to choose which sentences you get and do things like set waypoints, but google seems very quiet on these things.
I don't want to pay $350 for the full standard, can anyone help with a pointer to the basic command set/format?
Cheers,
Joey
I just use $GPRMC for position data.
Leon Heller G1HSM
I typed "NMEA sentences" into Google. Top hit was:
http://www.gpsinformation.org/da...
and thence:
Excellent!
The input sentences are the same as the output ones, then there are a handful of SiRF sentences used to carry out housekeeping like setting the serial format and choosing which sentences to output.
Spot on, thanks.
As the typical module does things like keeping track of waypoints I might as well take advantage of it.
What I needed was "nmea input sentences"!
Sparkfun have a datasheet that is much more helpful than those at RF solutions:
http://www.sparkfun.com/datasheets/GPS/NMEA%20Reference%20Manual1.pdf
Cheers,
Joey
