Examining the SP1 .inc files I found a fantastic device - ATMega64HVE - which appears to have an on-chip integer 32/64 math extension engine - MEXT. Further investigations allowed me to reveal the entire new instruction subset and successfully assemble the test code with AVRASM2.
The listing reported total 159 instructions and listed them all (see the code below).
Besides, I discovered four new XMega instructions for enhanced XMega core. Here is the code and listing illustrating all I said above:
; File MEXT.asm: #pragma AVRPART CORE EXTENSIONS MEXT 1 ; Mega64HVE Math EXTension module instructions: mul.ll r0,r8,r16,r24 ; Multiply 64u x 64u = 128u mulsu.l r0,r4,r8,r12 ; Multiply 32s x 32u = 64s muls.l r0,r4,r8,r12 ; Multiply 32s x 32s = 64s mulu.l r0,r4,r8,r12 ; Multiply 32u x 32u = 64u mul.l r0,r4,r8 ; Multiply 32u x 32u = 32u mulsu.w r0,r2,r4 ; Multiply 16s x 16u = 32s muls.w r0,r2,r4 ; Multiply 16s x 16s = 32s mulu.w r0,r2,r4 ; Multiply 16u x 16u = 32u mul.w r0,r2,r4 ; Multiply 16u x 16u = 16u absxt.ll r8 ; Absolute value of 64 bit long long w/sign extend absxt.l r4 ; Absolute value of 32 bit long w/sign extend abs.ll r8 ; Absolute value of 64 bit long long abs.l r4 ; Absolute value of 32 bit long negts.ll r8 ; Negate and toggle sign of 64 bit long long negts.l r4 ; Negate and toggle sign of 32 bit long neg.ll r8 ; Negate a 64 bit long long neg.l r4 ; Negate a 32 bit long ror.ll r8 ; Rotate right a 64 bit long long ror.l r4 ; Rotate right a 32 bit long asr.ll r8 ; Arithmetically shift right a 64 bit long long asr.l r4 ; Arithmetically shift right a 32 bit long lsr.ll r8 ; Logically shift right a 64 bit long long lsr.l r4 ; Logically shift right a 32 bit long tst.ll r8 ; Test for zero or minus a 64 bit long long tst.l r4 ; Test for zero or minus a 32 bit long mov.ll r0,r8 ; Move a 64 bit long long mov.l r0,r4 ; Move a 32 bit long div.ll r0,r8 ; Divide 64u / 64u = 64u.64u div.l r0,r4 ; Divide 32u / 32u = 32u.32u divinit.l r4 ; Initialize a quad register for long division rsbc.l r0,r4 ; 32 bit reverse subtract w/carry rsub.l r0,r4 ; 32 bit reverse subtract sbc.l r0,r4 ; 32 bit subtract w/carry sub.l r0,r4 ; 32 bit subtract cpc.l r0,r4 ; 32 bit compare w/carry cp.l r0,r4 ; 32 bit compare adc.l r0,r4 ; 32 bit add w/carry add.l r0,r4 ; 32 bit add ; .lds.l r4,127 ; Load a 32 bit variable to quad register - didn't work yet listed ; .sts.l 127,r4 ; Store a quad register to 32 bit variable - didn't work yet listed #pragma AVRPART CORE CORE_VERSION V3XJ ; New XMega (core V3XJ) instructions: xch z,r1 ; Exchange r1 with RAM[Z} lac z,r2 ; Load And Clear R2 bits of RAM{Z} las z,r3 ; Load And Set R3 bits of RAM{Z} lat z,r4 ; Load And Toggle R4 bits of RAM{Z} .exit MEXT.lst: AVRASM ver. 2.1.42 C:\XAVR\Jim\Mega64HVE.asm Thu Dec 31 12:02:16 2009 ; Mega64HVE Math EXTension module instructions: 000000 fd1c 0880 mul.ll r0,r8,r16,r24 ; Multiply 64u x 64u = 128u 000002 fc8e 0740 mulsu.l r0,r4,r8,r12 ; Multiply 32s x 32u = 64s 000004 fc8e 0640 muls.l r0,r4,r8,r12 ; Multiply 32s x 32s = 64s 000006 fc8e 0540 mulu.l r0,r4,r8,r12 ; Multiply 32u x 32u = 64u 000008 fc4c 0040 mul.l r0,r4,r8 ; Multiply 32u x 32u = 32u 00000a fc2a 0300 mulsu.w r0,r2,r4 ; Multiply 16s x 16u = 32s 00000c fc2a 0200 muls.w r0,r2,r4 ; Multiply 16s x 16s = 32s 00000e fc2a 0100 mulu.w r0,r2,r4 ; Multiply 16u x 16u = 32u 000010 fc2a 0000 mul.w r0,r2,r4 ; Multiply 16u x 16u = 16u 000012 92b7 absxt.ll r8 ; Absolute value of 64 bit long long w/sign extend 000013 9257 absxt.l r4 ; Absolute value of 32 bit long w/sign extend 000014 92b6 abs.ll r8 ; Absolute value of 64 bit long long 000015 9256 abs.l r4 ; Absolute value of 32 bit long 000016 92b5 negts.ll r8 ; Negate and toggle sign of 64 bit long long 000017 9255 negts.l r4 ; Negate and toggle sign of 32 bit long 000018 92b4 neg.ll r8 ; Negate a 64 bit long long 000019 9254 neg.l r4 ; Negate a 32 bit long 00001a 92a7 ror.ll r8 ; Rotate right a 64 bit long long 00001b 9247 ror.l r4 ; Rotate right a 32 bit long 00001c 92a6 asr.ll r8 ; Arithmetically shift right a 64 bit long long 00001d 9246 asr.l r4 ; Arithmetically shift right a 32 bit long 00001e 92a5 lsr.ll r8 ; Logically shift right a 64 bit long long 00001f 9245 lsr.l r4 ; Logically shift right a 32 bit long 000020 92a4 tst.ll r8 ; Test for zero or minus a 64 bit long long 000021 9244 tst.l r4 ; Test for zero or minus a 32 bit long 000022 fe2d mov.ll r0,r8 ; Move a 64 bit long long 000023 fe0b mov.l r0,r4 ; Move a 32 bit long 000024 fe2c div.ll r0,r8 ; Divide 64u / 64u = 64u.64u 000025 fe0a div.l r0,r4 ; Divide 32u / 32u = 32u.32u 000026 fe6b divinit.l r4 ; Initialize a quad register for long division 000027 fa2b rsbc.l r0,r4 ; 32 bit reverse subtract w/carry 000028 fa0b rsub.l r0,r4 ; 32 bit reverse subtract 000029 f82b sbc.l r0,r4 ; 32 bit subtract w/carry 00002a f80b sub.l r0,r4 ; 32 bit subtract 00002b fa2a cpc.l r0,r4 ; 32 bit compare w/carry 00002c fa0a cp.l r0,r4 ; 32 bit compare 00002d f82a adc.l r0,r4 ; 32 bit add w/carry 00002e f80a add.l r0,r4 ; 32 bit add ; .lds.l r4,127 ; Load a 32 bit variable to quad register - didn't work yet listed ; .sts.l 127,r4 ; Store a quad register to 32 bit variable - didn't work yet listed #pragma AVRPART CORE CORE_VERSION V3XJ ; New XMega (core V3XJ) instructions: 00002f 9214 xch z,r1 ; Exchange r1 with RAM[Z} 000030 9226 lac z,r2 ; Load And Clear R2 bits of RAM{Z} 000031 9235 las z,r3 ; Load And Set R3 bits of RAM{Z} 000032 9247 lat z,r4 ; Load And Toggle R4 bits of RAM{Z} RESOURCE USE INFORMATION ------------------------ Notice: The register and instruction counts are symbol table hit counts, and hence implicitly used resources are not counted, eg, the 'lpm' instruction without operands implicitly uses r0 and z, none of which are counted. x,y,z are separate entities in the symbol table and are counted separately from r26..r31 here. .dseg memory usage only counts static data declared with .byte Register use summary: r0 : 21 r1 : 1 r2 : 5 r3 : 1 r4 : 28 r5 : 0 r6 : 0 r7 : 0 r8 : 15 r9 : 0 r10: 0 r11: 0 r12: 3 r13: 0 r14: 0 r15: 0 r16: 1 r17: 0 r18: 0 r19: 0 r20: 0 r21: 0 r22: 0 r23: 0 r24: 1 r25: 0 r26: 0 r27: 0 r28: 0 r29: 0 r30: 0 r31: 0 x : 0 y : 0 z : 4 Registers used: 10 out of 35 (28.6%) Instruction use summary: .lds : 0 .sts : 0 abs.l : 1 abs.ll: 1 absxt.l: 1 absxt.ll: 1 adc : 0 adc.l : 1 add : 0 add.l : 1 adiw : 0 and : 0 andi : 0 asr : 0 asr.l : 1 asr.ll: 1 bclr : 0 bld : 0 brbc : 0 brbs : 0 brcc : 0 brcs : 0 break : 0 breq : 0 brge : 0 brhc : 0 brhs : 0 brid : 0 brie : 0 brlo : 0 brlt : 0 brmi : 0 brne : 0 brpl : 0 brsh : 0 brtc : 0 brts : 0 brvc : 0 brvs : 0 bset : 0 bst : 0 call : 0 cbi : 0 cbr : 0 clc : 0 clh : 0 cli : 0 cln : 0 clr : 0 cls : 0 clt : 0 clv : 0 clz : 0 com : 0 cp : 0 cp.l : 1 cpc : 0 cpc.l : 1 cpi : 0 cpse : 0 dec : 0 des : 0 div.l : 1 div.ll: 1 divinit.l: 1 eicall: 0 eijmp : 0 elpm : 0 eor : 0 fmul : 0 fmuls : 0 fmulsu: 0 icall : 0 ijmp : 0 in : 0 inc : 0 jmp : 0 lac : 1 las : 1 lat : 1 ld : 0 ldd : 0 ldi : 0 lds : 0 lpm : 0 lsl : 0 lsr : 0 lsr.l : 1 lsr.ll: 1 mov : 0 mov.l : 1 mov.ll: 1 movw : 0 mul : 0 mul.l : 1 mul.ll: 1 mul.w : 1 muls : 0 muls.l: 1 muls.w: 1 mulsu : 0 mulsu.l: 1 mulsu.w: 1 mulu.l: 1 mulu.w: 1 neg : 0 neg.l : 1 neg.ll: 1 negts.l: 1 negts.ll: 1 nop : 0 or : 0 ori : 0 out : 0 pop : 0 push : 0 rcall : 0 ret : 0 reti : 0 rjmp : 0 rol : 0 ror : 0 ror.l : 1 ror.ll: 1 rsbc.l: 1 rsub.l: 1 sbc : 0 sbc.l : 1 sbci : 0 sbi : 0 sbic : 0 sbis : 0 sbiw : 0 sbr : 0 sbrc : 0 sbrs : 0 sec : 0 seh : 0 sei : 0 sen : 0 ser : 0 ses : 0 set : 0 sev : 0 sez : 0 sleep : 0 spm : 0 st : 0 std : 0 sts : 0 sub : 0 sub.l : 1 subi : 0 swap : 0 tst : 0 tst.l : 1 tst.ll: 1 wdr : 0 xch : 1 Instructions used: 42 out of 159 (26.4%) Memory use summary [bytes]: Segment Begin End Code Data Used Size Use% --------------------------------------------------------------- [.cseg] 0x000000 0x000066 102 0 102 unknown - [.dseg] 0x000060 0x000060 0 0 0 unknown - [.eseg] 0x000000 0x000000 0 0 0 unknown - Assembly complete, 0 errors, 0 warnings
Enjoy, and Happy New Year to all! :P
