Hi guys,
I think I may have popped my dragon, i think it got 9V into the Target Voltage pin.
What are the symptoms? I can't get it to read my target chip, it says
"Setting device parameters.. OK!
Entering programming mode.. FAILED!
Leaving programming mode.. OK!"
I know the chip works because I reprogrammed it with HVP and checked the SPIE was on using the STK500
And surely the cip should have blown at the same time :?
