ATZB-A24-ULF hardware issue
11 posts / 0 new
Hi !
I have one/or more hardware issues.
I'm using ATZB-A24-ULF modules. I've done my own PCB design similar to Meshnetics MeshBean AMP board (TPS63001DRC DC-DC).
In past few weeks I've "damaged" 3 modules. I use USB power supply 5.15 V, I measure voltage on module 3.31 V.
I think problem happens whan I plug in USB power supply.
I'm able to recognize(read signature) and program module via JTAG correctly, I uploaded my own app(not using Zigbee network) to trigger some ports and read RTC and send RTC data over USART, everything works, but I can't start network. I think problem is with RF chip AT86RF230.
I through 1 module away, but guess what, other two modules started started to work !
Did anyone have similar problem?
Regards Mesko.
If you are not using BitCloud then what software do you use? If is is some self-made software then describe it in more details, like what frequency is used to communicate to the RF chip and other?
Sorry, I forgot to mention it's BitCloud.
Then what exactly "I can't start network" means? What status code is returned?
I don't receive any status code, that's the problem.
And it is only one module out of 3 with the same firmware that has this problem? Do they have the same fuse settings? What pins of the module are connected?
This one (Meshnetics is manufac.) I replaced with new module (Atmel). It was totaly quit, but I could recognize it and program it, but nothing worked (USART, GPIO..).
With other 2 modules I had similar problem; I couldn't start network(didn't receive any status code), USART, GPIO... worked fine. Now everything works with these 2 modules.
With all 3 modules I also had problem that I couldn't recognize them (Read Signature).
Fuse settings are (for all of them, I've never changed fuse bits):
Ext : 0xFF
High : 0x9C
Low : 0x62
Most of pins are "free".
I use I2C, USART, JTAG, RESET button.
So in the end 2 modules are working and one not with the same firmware, or what?
Yes.
Can't really suggest something meaningful here. If you have an oscilloscope then try to check RF SPI lines (should be on the module's pins).
OK, that's hardware problem, it's not repeatable like software issue.
I just wanted to know if anyone had similar experience.
Anyway, thank You Alexru, for trying.
