Has anyone used one of these at higher than the rated 3.3v?
Reason I ask is that I have an interface circuit talking to something that doesn't quite meet the published specs; previous 5v versions of the system work fine while 3.3v versions - constrained by this display chip - are intermittent and generally less happy.
The device manual has a change note that indicates a reduction in vmax from a previous 5.5v with no explanation, and a couple of points within whereby they suggest certain pins be kept in one state or the other if the voltage is less than 4v - which it *is now* - but doesn't say whether this is merely a characterisation to indicate everything works fine at 3.3v or a change in manufacturing that will let the magic smoke out at 5v...
I'm currently very tempted to crank up the voltage and see where smoke appears, but if anyone's tried this, it'd be nice to know!
Ta,
Neil
