SinaProg 2.0 Fuse problem
3 posts / 0 new
I have installed SinaProg 2.0 to program/configure an AVR-MINI board with M328P micro. This board has the Ardunio bootloader installed. The SinaProg board is able to communicate with the micro, read signature bytes, flash, eeprom, etc. However, I am confused by the "Advanced" tab where the fuse values, lock bits, and OSC cal values are displayed and set.
When I read the values, a message is displayed that says the fuse values are being read, then the message says OK, but none of the fuse values shown on screen change (everything is "x 00"). For certain, all of the fuses are not programmed. Shouldn't these display boxes show the actual fuse values ?
File "Fuses.txt" does not have any entries for the M328P, but that should keep it from showing the hex value of fuses - would it ?
You cannot program fuses with a bootloader? You need an ISP programmer to do that to a 328.
AHHHHHH - DUH - Thanks.
