How to build WinAVR
19 posts / 0 new
i am using WinAVR 20100110 which is using old avr-libc
how i can update with the new avr-libc
P.Ashok Kumar
thank you atomicdog it is very difficult for me to understand Building the Tool chain like "Build script",
"patch"
P.Ashok Kumar
There is a later avr-libc as part of the AVR Studio 5 download. Be warned that the download is 0.5GB and has to unpack about 2GB of data for you simply to access the 20MB (or whatever it is) of avr-libc
Now the AVR Studio5 is Beta version for final release/Stable again i have Download the full 0.5Gb or
only service pack to be downloaded and when we can expect the latest Release.
P.Ashok Kumar
You clearly haven't been reading the AS5 forum here if you believe that - it's FULL of bugs and missing functionality. In fact I'd call it an alpha rather than a beta as there's still parts left to be implemented.
I am not interested much on AS5 only i require WINAVR with latest avr-libc so i thought i can use the new AS5 which is having GCC with latest avr-libc.
for Building Winavr with latest avr-libc i have to learn lot of other tools. there is any other source of Winavr with new avr-libc available. I am using now WinAVR-20100110.
P.Ashok Kumar
The latest release on the official avr-libc site is 1.7.1 released on 2011-02-16.
I don't know whether that contains all the patches that Atmel has applied to "the toolchain", though.
ok i downloaded the avr-libc-1.7.1.tar.bz2.sig and avr-libc-1.7.1.tar.bz2 i don't know what to do with that
[slaps forehead]
It just sunk in that you want binaries (right?). Sorry. No binaries there.
So now we're back to the link that atomicdog posted above, where the steps to build on Windows are described. Not something I've gone through myself, so can't contribute much more than what the steps in that description gives..
Surely you just download AS5 and take the Avr-gcc and avr-libc from it?
I tried the link the examples in the link are old some tools are Changed with new version and type?? i am not able to understand many of commands and procedure to Building WINAVR so now i will not build WINAVR. I will start Download AS5 :evil:
What all the files i have to copy from AS5 to WINAVR.
Finaly I started to download the AS5 :evil:.
my internet speed 10KB/sec-20KB/sec so it will take at least 5hrs to 10hrs.
..\Atmel\AVR Studio 5.0\extensions\Application\AVR Toolchain
I have a folder "C:\Program Files\Atmel\AVR Studio 5.0\extensions\Application\AVR Toolchain\avr" that seems to correspond to the folder "C:\WinAVR-20100110\avr".
Verify it yourself when you have AS5 downloaded.
Don't forget to back up WinAVR (and/or make sure you have a valid installer for 20100110) before you start copying stuff around!
Why would you need to copy stuff? In your PATH just replace:
x:\WinAVR20100110\bin;x:\WinAVR20100110\utils\bin
with
x:\Program Files\Atmel\AVR Studio 5.0\extensions\Application\AVR Toolchain\bin
and now when avr-gcc is run it'll be the new one, not the old one. avr-gcc has built in (relative) paths to where it will locate everything else.
(one thing this highlights is that AS5 does not have the utils - major shame!!)
AVR Toolchain puts the coreutils programs in the bin folder instead of a separate one like WinAVR.
Thank you all
finally my WinAVR 20100110 updated successfully.
i copied all the file from C:\Program Files\Atmel\AVR Studio 5.0\extensions\Application\AVR Toolchain
to C:\WinAVR-20100110.
Note:i am not using AVRDUDE,SimulAVR..etc.so no idea these tools will work or not.
Result orginal WinAVR 20100110
> "make.exe" all
-------- begin --------
avr-gcc (WinAVR 20100110) 4.3.3
Copyright (C) 2008 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Compiling C: main.c
avr-gcc -c -mmcu=atmega64 -I. -gdwarf-2 -DF_CPU=4000000UL -Os -mcall-prologues -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wundef -Wa,-adhlns=obj/main.lst  -std=gnu99 -Wundef -MD -MP -MF .dep/main.o.d main.c -o obj/main.o
Linking: main.elf
avr-gcc -mmcu=atmega64 -I. -gdwarf-2 -DF_CPU=4000000UL -Os -mcall-prologues -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wundef -Wa,-adhlns=obj/main.o  -std=gnu99 -Wundef -MD -MP -MF .dep/main.elf.d obj/main.o --output main.elf -Wl,-Map=main.map,--cref    -lm
Creating load file for Flash: main.hex
avr-objcopy -O ihex -R .eeprom main.elf main.hex
Creating load file for EEPROM: main.eep
avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" \
	--change-section-lma .eeprom=0 -O ihex main.elf main.eep
Creating Extended Listing: main.lss
avr-objdump -h -S main.elf > main.lss
Creating Symbol Table: main.sym
avr-nm -n main.elf > main.sym
Size after:
main.elf  :
section            size      addr
.data                20   8388864
.text             24482         0
.bss                327   8388884
.eeprom             685   8454144
.debug_aranges       32         0
.debug_pubnames    7247         0
.debug_info       12432         0
.debug_abbrev       671         0
.debug_line       24721         0
.debug_frame       1424         0
.debug_str         5821         0
.debug_loc         1771         0
.debug_ranges       360         0
Total             79993
-------- end --------
> Process Exit Code: 0
> Time Taken: 00:11
Result Updated WinAVR 20100110
avr-gcc (AVR_8_bit_GNU_Toolchain_3.2.0_253) 4.5.1
Copyright (C) 2010 Free Software Foundation, Inc.
Compiling C: main.c
Linking: main.elf
Size after:
main.elf  :
section            size      addr
.data                20   8388864
.text             24578         0
.bss                327   8388884
.eeprom             685   8454144
.stab              1740         0
.stabstr            133         0
.debug_aranges       32         0
.debug_info       14955         0
.debug_abbrev       682         0
.debug_line       26119         0
.debug_frame       1424         0
.debug_str         5864         0
.debug_loc         3475         0
.debug_pubtypes      86         0
Total             87367
> Time Taken: 00:12
