Dealing with interrupts and scrolling lists in assembly
9 posts / 0 new
I'm having a bit of trouble making my LCD program run with interrupts. I have to make it so that the screen will scroll up and down (vertical, not horizontal, scrolling) when I press one of two buttons (one for up, one for down). When I load the program it does not do anything, as far as I know it doesn't even reset the lcd. The only new things are the addition of the interrupts code - the rest of the program works (go here for the program code without interrupts: https://www.avrfreaks.net/index.p...)
Thanks in advance!
Whoops, here's my program code:
; LCD version 15
; Using Port A
; Scrolling Strings with buttons
.INCLUDE "M2560DEF.INC"
;Interrupts setup
.org INT0addr						;Up
	jmp up_button_interrupt
.org INT1addr						;Down
	jmp down_button_interrupt
.def data_reg = r24
.def delay_reg1 = r26
.def delay_reg2 = r27
.def mult_reg = r17
.def counter_reg = r28
.equ control = portb
.equ data = porta
.equ dataDR = ddra
.equ controlDR = ddrb
.equ rw = 7
.equ rs = 6
.equ enable = 5
;LCD codes
.equ initial_pulse = 0b00110000
.equ four_bit_mode_com = 0b00100000
.equ ndisp_charfont_com = 0b00101000
.equ disp_on_curs_off_com = 0x0C
.equ disp_off_com = 0b0000_1000
.equ disp_clear_com = 0b0000_0001
.equ entry_mode_com = 0b00000110
.equ disp_on_blink_com = 0b00001100
.equ curs_pos2_com = 0b1000_0001
.equ disp_H_com = 0b0100_1010
.equ curs_pos1_com = 0x80
.equ curs_pos1_2line = 0b1100_0000
	rjmp main
main:
	ldi r16, LOW(RAMEND)	; stack setup
	out SPL, r16
	ldi r16, HIGH(RAMEND)
	out SPH, r16
	ser r16
	out dataDR,r16
	out controlDR,r16
	clr r16
	out data,r16
	out control,r16
	ldi counter_reg,1		;Initialize Counter to one
	rcall init
	; Turn display on, blinking, cursor
	ldi data_reg,disp_on_blink_com
	rcall sendcom
	ldi zh, HIGH(string*2)		;Print Hello LCD
	ldi zl, LOW(string*2)
	rcall print_string
	rcall wait1sec
	rcall wait1sec
	rcall clearLCD
	ldi r16,0b0000_1010			;Enable Interrupts on falling edge on EICRA 0 and 1 (pins 21 and 20) (PD0 and PD1)
	sts EICRA,r16
	ldi r16,(1<<INT0)+(1<<INT1) ; int masks 0 and 1 set
	out EIMSK,r16
	sei							;Enable Global Interrupts
	rjmp loop
	;End MAIN
loop:
	rjmp loop
button_press:
	cpi counter_reg,1
	breq one
	cpi counter_reg,2
	breq two
	cpi counter_reg,3
	breq three
	cpi counter_reg,4
	breq four
one:
	rcall clearLCD
	ldi zh, HIGH(string1*2)
	ldi zl, LOW(string1*2)
	rcall print_string
	ldi data_reg,curs_pos1_2line	;Cursor on second line
	rcall sendcom
	ldi zh, HIGH(string2*2+8)
	ldi zl, LOW(string2*2+8)
	rcall print_string
	ret
two:
	rcall clearLCD
	ldi zh, HIGH(string2*2)
	ldi zl, LOW(string2*2)
	rcall print_string
	rcall sendcom
	ldi zh, HIGH(string3*2)
	ldi zl, LOW(string3*2)
	rcall print_string
	ret
three:
	rcall clearLCD
	rcall print_string
	rcall sendcom
	ldi zh, HIGH(string4*2)
	ldi zl, LOW(string4*2)
	rcall print_string
	ret
four:
	rcall clearLCD
	rcall print_string
	rcall sendcom
	rcall print_string
	ret
string:
	.db "Hello LCD",0x00
string1:
	.db "Hi, my name is",0x00
string2:
	.db "Slim Shady",0x00
string3:
	.db "Hi kids do you",0x00
string4:
	.db "like violence?",0x00
; Print String
; MUST set z with the string you want to print FIRST
print_string:
	;ldi zh, HIGH(string*2)
	;ldi zl, LOW(string*2)
print_loop:
	; Print a character
	lpm
	tst r0
	breq string_finished
	mov data_reg, r0
	push zh
	push zl
	rcall senddat
	pop zl
	pop zh
	adiw zl,1
	rjmp print_loop
string_finished:
	ret
init:
	rcall wait125
	cbi control,rs			;Register select: command
	cbi control,rw			;RW select, write
	rcall first_pulse
	rcall first_pulse
	rcall first_pulse
	rcall wait46
	ldi r16,four_bit_mode_com			;Start in 4-bit mode
	out data,r16
	sbi control,enable			;Set Enable
	nop
	cbi control,enable			;Clear Enable
	rcall wait46
	ldi data_reg,ndisp_charfont_com	;Set number of display lines and character font
	rcall sendcom
	ldi data_reg,disp_on_blink_com	;Display on cursor blinking
	rcall sendcom
	ldi data_reg,disp_clear_com	;Display clear
	rcall sendcom
	ldi data_reg,entry_mode_com	;Entry mode set
	rcall sendcom
	;ldi data_reg,curs_pos1_com
	;rcall sendcom
	ret
first_pulse:
	rcall wait125
	ldi r16,initial_pulse
	out data,r16
	nop
	nop
	ret
clearLCD:					;Routine to clear the LCD screen
	rcall sendcom
	ret
setcursor:
	ldi r31,curs_pos1_com
	add r16,r31				;Add the spaces
	mov data_reg,r16
	rcall sendcom
	ret
sendcom:				;Send Command - because we are using 4-bit mode, must send twice
	ser r16
	out dataDR,r16
	out data,data_reg		;Send High
	nop
	nop
	rcall delay5msec
	swap data_reg			;Swap Nibbles
	out data,data_reg		;Send Low
	nop
	nop
	rcall delay5msec
	ret
senddat:				;Send Data - because we are using 4-bit mode, must send twice
	sbi control,rs		;Register select: data
	ser r16
	out dataDR,r16
	nop
	nop
	rcall delay5msec
	nop
	nop
	rcall delay5msec
	ret
;For now this code is not being used
LCD_busy:
	cbi ddra,7			;Set BF as input
check:
	sbic pina,7
	rjmp check
	sbi ddra,7			;Set back as output
	ret
wait1sec:
	ldi mult_reg,64			;Determines pause length, in this case 1s
outer_loop2:
	ldi delay_reg1,low(3037)
	ldi delay_reg2,high(3037)
delay_loop2:
	adiw delay_reg1,1
	brne delay_loop2
	dec mult_reg
	brne outer_loop2
	ret
wait125:
	ldi mult_reg,8			;Determines pause length, in this case 125ms
outer_loop:
delay_loop:
	adiw delay_reg1,1
	brne delay_loop
	dec mult_reg
	brne outer_loop
	ret
wait46:
	ldi mult_reg,3			;Determines pause length, in this case 46ms
outer_loop1:
delay_loop1:
	adiw delay_reg1,1
	brne delay_loop1
	dec mult_reg
	brne outer_loop1
	ret
delay100usec:		; 255 * 6 =~ 1600 cycles
	ldi delay_reg1, 255
    loop100:
    	nop
    	nop
    	nop
	dec delay_reg1
	brne loop100
	ret
delay5msec:		; 80 * 4 * 255 =~ 80000 cycles
	ldi delay_reg1, 80
    outerloop2:
	ldi delay_reg2, 255
    innerloop2:
	dec delay_reg2
	nop
	brne innerloop2
	dec delay_reg1
	brne outerloop2
	ret
up_button_interrupt:
	rjmp up
	reti
down_button_interrupt:
	rjmp down
	reti
up:
	clr r16
	cpse counter_reg,r16
	rcall res1
	dec counter_reg
	rcall button_press
down:
	ldi r16,4
	rcall res2
	inc counter_reg
	rcall button_press
res1:
	ldi counter_reg,5
	ret
res2:
	ldi counter_reg,0
	ret
This is the first line of code in your program:
.org INT0addr                  ;Up
Guess what happens first? You jump to up_button_interrupt, hit the reti and go off into wonderland since your stack isn't initialized. The first line of code needs to be a jump to your reset routine, in your case a jump to main.
Also you don't show the routine button_press, so I don't know if you return from it, but you're going to have other problems. Take your UP: routine for example, you do a call to button_press and assuming you return from that call, the next thing you do is run into Down:. I'm assuming that's not what you want to do.
Guess what happens first? You jump to up_button_interrupt, ...
Do you understand what he's saying here? You've used .org directives to place the jumps to the handlers at the correct addresses, but then you follow them with your jump to main (left over from your previous version). Unfortunately you don't have a .org back to 0x00 prior to that jump, so it immediately follows the second interrupt vector. It needs to be at 0x00, and the way most people do it is to have it be the first instruction.
While it seems like you could just put a .org 0x00 in front of the jump to main, that won't solve the problem for the following reason. That jump will get in the right place, but main and its code will then follow until it tries to overlay those two interrupt vectors that you .orged earlier. So you'd need
      .org  interrupt_vector_name
      jmp   interrupt vector
      .org  other_vector_name
      jmp   to_that_vector
      .org  0x00     // gets us back to 0x0000
      jmp   main
      .org  some_address_after the vectors
main: your_code
It's easier to have:
      jmp    main  // defaults to 0x00
      .org   vector1
      jmp    vector1_handler
      .org   vector2
      jmp    vector2_handler
      .org   beyond_vectors
main: your_code
What I prefer, as does the King of the Assembly World Captain Giovannious, is to put in all of the vectors explicitly, and send all of the inactive ones to a single reti instruction. Cut and paste and you're done, with no ambiguity.
But I digress. I was going to suggest pulling out all the LCD stuff and stick in a couple of LEDs (breadboard? dev board that's easy to rewire?), one for scroll up and the other for scroll down. Get the buttons and interrupts all working simulating the LCD, and when you're happy with that, put the LCD code back in place.
Chuck Baird
http://www.cbaird.org
Thanks guys! Here is my working program:
; LCD version 15
; Using Port A
.def data_reg = r24
.def mult_reg = r17
.equ data = porta
.equ dataDR = ddra
.equ rw = 7
.equ rs = 6
.equ enable = 5
;LCD codes
	rjmp main
;Interrupts setup
.org INT0addr						;Up
.org INT1addr						;Down
main:
	out SPL, r16
	out SPH, r16
	ser r16
	out dataDR,r16
	out controlDR,r16
	clr r16
	out data,r16
	out control,r16
	rcall init
	rcall sendcom
	rcall print_string
	rcall wait1sec
	rcall wait1sec
	rcall clearLCD
	ldi r16,0b0000_1111			;Enable Interrupts on rising edge on EICRA 0 and 1 (pins 21 and 20) (PD0 and PD1)
	sts EICRA,r16
	out EIMSK,r16
	rcall button_press
	rjmp loop
	;End MAIN
loop:
	rjmp loop
check_counter_up:
	clr r16
	cpse counter_reg,r16	;Checks for counter = 0
	ret
	ldi counter_reg,4
	ret
check_counter_down:
	ldi r16,5
	cpse counter_reg,r16	;Checks for counter = 5
	ret
	ldi counter_reg,1
	ret
button_press:
	rcall check_counter_up
	rcall check_counter_down
	cpi counter_reg,1
	breq one
	cpi counter_reg,2
	breq two
	cpi counter_reg,3
	breq three
	cpi counter_reg,4
	breq four
one:
	rcall clearLCD
	rcall print_string
	rcall sendcom
	rcall print_string
	ret
two:
	rcall clearLCD
	rcall print_string
	rcall sendcom
	rcall print_string
	ret
three:
	rcall clearLCD
	rcall print_string
	rcall sendcom
	rcall print_string
	ret
four:
	rcall clearLCD
	rcall print_string
	rcall sendcom
	rcall print_string
	ret
string:
string1:
string2:
string3:
string4:
; Print String
print_string:
print_loop:
	; Print a character
	lpm
	tst r0
	mov data_reg, r0
	push zh
	push zl
	rcall senddat
	pop zl
	pop zh
	adiw zl,1
	rjmp print_loop
string_finished:
	ret
init:
	rcall wait125
	rcall first_pulse
	rcall first_pulse
	rcall first_pulse
	rcall wait46
	out data,r16
	nop
	rcall wait46
	rcall sendcom
	rcall sendcom
	rcall sendcom
	rcall sendcom
	;rcall sendcom
	ret
first_pulse:
	rcall wait125
	out data,r16
	nop
	nop
	ret
	rcall sendcom
	ret
setcursor:
	mov data_reg,r16
	rcall sendcom
	ret
	ser r16
	out dataDR,r16
	nop
	nop
	rcall delay5msec
	nop
	nop
	rcall delay5msec
	ret
	ser r16
	out dataDR,r16
	nop
	nop
	rcall delay5msec
	nop
	nop
	rcall delay5msec
	ret
LCD_busy:
check:
	sbic pina,7
	rjmp check
	ret
wait1sec:
outer_loop2:
delay_loop2:
	adiw delay_reg1,1
	brne delay_loop2
	dec mult_reg
	brne outer_loop2
	ret
debounce:				;Basically a pause that waits long enough until the switch has stopped bouncing.
	ldi r17,16			;In this case, 250ms
outer_loop_d:
	ldi r24,low(3037)
	ldi r25,high(3037)
delay_loop_d:
	adiw r24,1			;ADIW and BRNE both take 2 cycles to execute. 4x(2^16 - 3037) ~= 250,000 cycles
	brne delay_loop_d
	dec r17				;250,000 x whatever the value of r17 is gives you total number of cycles to wait
	brne outer_loop_d
	ret
wait125:
outer_loop:
delay_loop:
	adiw delay_reg1,1
	brne delay_loop
	dec mult_reg
	brne outer_loop
	ret
wait46:
outer_loop1:
delay_loop1:
	adiw delay_reg1,1
	brne delay_loop1
	dec mult_reg
	brne outer_loop1
	ret
	ldi delay_reg1, 255
    loop100:
    	nop
    	nop
    	nop
	dec delay_reg1
	brne loop100
	ret
	ldi delay_reg1, 80
    outerloop2:
	ldi delay_reg2, 255
    innerloop2:
	dec delay_reg2
	nop
	brne innerloop2
	dec delay_reg1
	brne outerloop2
	ret
	rcall debounce
	inc counter_reg
	rcall button_press
	;ldi r16,(1<<INT0)+(1<<INT1) ; int masks 0 and 1 set
	;out EIMSK,r16
	reti
	rcall debounce
	dec counter_reg
	rcall button_press
	;out EIMSK,r16
	reti
I have a couple of questions: one, it works pretty good, but sometimes it skips two lines instead of one. I have already debounced the switches at the very beginning of the interrupts with a 250ms delay - do I need a bigger delay or is there an error in my code that could be causing this?
Two, it seems even to me that the program I came up with, with the whole "jump here if one, or here if two...etc" is kind of long and inefficient. I'm just learning AVR assembler now (I've been going at it for about two weeks); what can I do to make it be more efficient? Is there a way I could use some kind of pointer and increment and decrement it to go up and down the list?
Thanks in advance!
You really want to stop at this point as your program has a number of serious defects. First up, don't use pushbuttons on interrupts - has been discussed a zillion times before. Have a read of my tutorial 'the trap when using interrupts'. Your program is getting larger but yet you have dedicated registers for certain variables. You'll soon run into a brick wall metaphorically as you'll run out of registers. Learn to use the ram to store your variables. Then learn about storing and restoring the processor state when you enter/exit a isr. Why do you not use C? Then see how the C compiler handles things at an assembler level.
You really want to stop at this point....
He's got too much enthusiasm to take the time to stop and clean up his code. Once he gets something 'working' he just plunges ahead to the next idea. He has ignored many of the suggestions made to him in his previous thread https://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=103663&start=0.
Don
You're not handling your interrupts correctly. At a minimum you need to save the status register as soon as you enter the ISR (dedicated register or push on the stack), then restore the status register just before the reti. You will also learn that you need to keep your ISR's short and fast, use the ISR to set flags that your main routine can work with. This allows other interrupts to occur since you don't spend all your time in the ISR's.
