How to control an LCD using Assembly???
74 posts / 0 new
Pages
I'm assuming that because it's on an Arduino board it is... the other program works just fine just like it is right now (the one that outputs "Hi my name is").
A curious thing I noticed: I uploaded my code once, and the previous text on the LCD cleared, but no character was displayed. I uploaded the same code again, and this was displayed: "@e my na" (the previous text was "Hi my name is"). I kept doing it and it would alternate like that, once clear, once with "@e my na".
This implies that the LCD initialization is not working consistently. Your sendcom routine incorporates a delay and the same delay is used for all of the commands. If you look at the datasheet you will see that some of the commands take longer to complete than others. If you are going to use a single delay for all commands (which is not a bad idea when you are just starting out) then it has to accommodate the worst case.
After you get your program functioning properly we can work on cleaning up some of your extraneous code.
Don
OMG I MADE IT WORK JGKJFDSKSFIDBIBDYFSVB!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Ok, ok... lemme calm down...
Check out my code. You will see I'm using r24 for storing commands and data when I pass them on to sendcom and senddat. You will see also that both of those commands have several waits. What is the register I'm using to store the wait variable? R24... whoops.
TOTAL newb mistake.
1) Which is why it's GOOD to define registers as meaningful names when using assembly
2) Why it's GREAT to learn C and be done with it, for the MOST ( +90% ) part.
Congrats !
2) WinAvr 20100110
A) Avr Dragon ver. 1
B) Avr MKII ISP, 2009 model
C) MKII JTAGICE ver. 1
I tried to .equ the registers but the assembler wouldn't let me (I'm using AVR Studio 4)...
Anyway, here is my code, in all its newfound glory
; LCD version 7
; Using Port A
; IT WORKS!!!
.INCLUDE "M2560DEF.INC"
.equ control = portb
.equ data = porta
.equ dataDR = ddra
.equ controlDR = ddrb
.equ rw = 7
.equ rs = 6
.equ enable = 5
;LCD codes
.equ initial_pulse = 0b00110000
.equ four_bit_mode_com = 0b00100000
.equ ndisp_charfont_com = 0b00101000
.equ disp_on_curs_off_com = 0x0C
.equ disp_off_com = 0b0000_1000
.equ disp_clear_com = 0b0000_0001
.equ entry_mode_com = 0b00000110
.equ disp_on_blink_com = 0b00001100
.equ curs_pos2_com = 0b1000_0001
.equ disp_H_com = 0b0100_1010
.equ curs_pos1_com = 0x80
	rjmp main
main:
	ldi r16, LOW(RAMEND)	; stack setup
	out SPL, r16
	ldi r16, HIGH(RAMEND)
	out SPH, r16
	ser r16
	out dataDR,r16
	out controlDR,r16
	clr r16
	out data,r16
	out control,r16
	rcall init
	;ldi r24,disp_clear_com	;Display clear
	;rcall sendcom
	;ldi r24,disp_off_com	;Display off
	;rcall sendcom
	; Turn display on, blinking, cursor
	ldi r24,disp_on_blink_com
	rcall sendcom
	ldi r24,curs_pos2_com	;Position Cursor on second position
	rcall sendcom
	ldi r24,'A'	;Display 'A'
	rcall senddat
	ldi r24,'B'
	rcall senddat
	rcall wait1sec
	rcall clearLCD
	rjmp loop
	;End MAIN
loop:
	rjmp loop
init:
	rcall wait125
	cbi control,rs			;Register select: command
	cbi control,rw			;RW select, write
	rcall first_pulse
	rcall first_pulse
	rcall first_pulse
	rcall wait125
	ldi r16,four_bit_mode_com			;Start in 4-bit mode
	out data,r16
	sbi control,enable			;Set Enable
	rcall wait46
	cbi control,enable			;Clear Enable
	rcall wait46
	ldi r24,ndisp_charfont_com	;Set number of display lines and character font
	rcall sendcom
	ldi r24,disp_on_blink_com	;Display on cursor blinking
	rcall sendcom
	rcall sendcom
	ldi r24,entry_mode_com	;Entry mode set
	rcall sendcom
	;ldi r24,curs_pos1_com
	;rcall sendcom
	ret
first_pulse:
	rcall wait125
	ldi r16,initial_pulse
	out data,r16
	rcall wait125
	rcall wait125
	ret
clearLCD:					;Routine to clear the LCD screen
	rcall sendcom
	ret
sendcom:				;Send Command - because we are using 4-bit mode, must send twice
	ser r16
	out dataDR,r16
	out data,r24		;Send High
	rcall wait46
	rcall wait46
	rcall wait46
	swap r24			;Swap Nibbles
	out data,r24		;Send Low
	rcall wait46
	rcall wait46
	rcall wait46
	ret
senddat:				;Send Data - because we are using 4-bit mode, must send twice
	sbi control,rs		;Register select: data
	ser r16
	out dataDR,r16
	rcall wait46
	rcall wait46
	rcall wait46
	rcall wait46
	rcall delay100usec
	rcall wait46
	ret
;For now this code is not being used
LCD_busy:
	cbi ddra,7			;Set BF as input
check:
	sbic pina,7
	rjmp check
	sbi ddra,7			;Set back as output
	ret
wait1sec:
	ldi r17,64			;Determines pause length, in this case 1s
outer_loop2:
	ldi r26,low(3037)
	ldi r27,high(3037)
delay_loop2:
	adiw r26,1
	brne delay_loop2
	dec r17
	brne outer_loop2
	ret
wait125:
	ldi r17,8			;Determines pause length, in this case 125ms
outer_loop:
	ldi r26,low(3037)
	ldi r27,high(3037)
delay_loop:
	adiw r26,1
	brne delay_loop
	dec r17
	brne outer_loop
	ret
wait46:
	ldi r17,3			;Determines pause length, in this case 46ms
outer_loop1:
	ldi r26,low(3037)
	ldi r27,high(3037)
delay_loop1:
	adiw r26,1
	brne delay_loop1
	dec r17
	brne outer_loop1
	ret
delay100usec:		; 255 * 6 =~ 1600 cycles
	ldi r26, 255
    loop100:
    	nop
    	nop
    	nop
	dec r26
	brne loop100
	ret
You use .def for registers, NOT .equ ! I suggest using hex for your LCD EQUs, it's too easy to make a typing error using 1's & 0's. Use the power of your PC and save yourself time ( statistically, you'll make those typing errors eventually... on a bigger app. than this. ).
2) WinAvr 20100110
We are back to programming style. I suggest using binary for the LCD equates because the information itself is bitmapped. The overall 'value', be it expressed in hex, decimal, octal or zorkian is irrelevant. It is the individual bits that have meaning. Many 'C' programmers can't do this due to limitations of their compiler, but there is no reason for assembly language programmers to self impose such a restriction.
Don
Ok guys, I managed to make it work with characters. Now I want to make it output strings... but I'm having problems with that too =(
My program outputs "AB" to the second and third spaces in the LCD, waits a second, and clears the LCD. Afterward it should print the string "Hello LCD" but it isn't... At the moment I am searching for examples and trying to figure out the mechanics of the stack pointer...
Here's the code:
; LCD version 7
; Using Port A
; IT WORKS!!!
.def data_reg = r24
.def delay_reg1 = r26
.def delay_reg2 = r27
.def mult_reg = r17
.equ data = porta
.equ dataDR = ddra
.equ rw = 7
.equ rs = 6
.equ enable = 5
;LCD codes
	rjmp main
main:
	out SPL, r16
	out SPH, r16
	ser r16
	out dataDR,r16
	out controlDR,r16
	clr r16
	out data,r16
	out control,r16
	rcall init
	;ldi data_reg,disp_clear_com	;Display clear
	;rcall sendcom
	;ldi data_reg,disp_off_com	;Display off
	;rcall sendcom
	ldi data_reg,disp_on_blink_com
	rcall sendcom
	ldi data_reg,curs_pos2_com	;Position Cursor on second position
	rcall sendcom
	ldi data_reg,'A'	;Display 'A'
	rcall senddat
	ldi data_reg,'B'
	rcall senddat
	rcall wait1sec
	rcall clearLCD
	rjmp print_string
	;rjmp loop
	;End MAIN
loop:
	rjmp loop
string:
	.db "Hello LCD",0x00
	ldi zh, HIGH(string*2)
	ldi zl, LOW(string*2)
print_string:
	; Print a character
	push zh
	push zl
	lpm
	tst r0
	breq string_finished
	mov data_reg, r0
	rcall senddat
	pop zl
	pop zh
	adiw zl,1
	rjmp print_string
string_finished:
	rjmp loop
init:
	rcall wait125
	rcall first_pulse
	rcall first_pulse
	rcall first_pulse
	rcall wait46
	out data,r16
	nop
	rcall wait46
	ldi data_reg,ndisp_charfont_com	;Set number of display lines and character font
	rcall sendcom
	ldi data_reg,disp_on_blink_com	;Display on cursor blinking
	rcall sendcom
	rcall sendcom
	ldi data_reg,entry_mode_com	;Entry mode set
	rcall sendcom
	;ldi data_reg,curs_pos1_com
	;rcall sendcom
	ret
first_pulse:
	rcall wait125
	out data,r16
	nop
	nop
	ret
	rcall sendcom
	ret
	ser r16
	out dataDR,r16
	out data,data_reg		;Send High
	nop
	nop
	rcall wait46
	swap data_reg			;Swap Nibbles
	out data,data_reg		;Send Low
	nop
	nop
	rcall wait46
	ret
	ser r16
	out dataDR,r16
	nop
	nop
	rcall wait46
	nop
	nop
	rcall wait46
	ret
LCD_busy:
check:
	sbic pina,7
	rjmp check
	ret
wait1sec:
	ldi mult_reg,64			;Determines pause length, in this case 1s
outer_loop2:
	ldi delay_reg1,low(3037)
	ldi delay_reg2,high(3037)
delay_loop2:
	adiw delay_reg1,1
	brne delay_loop2
	dec mult_reg
	brne outer_loop2
	ret
wait125:
	ldi mult_reg,8			;Determines pause length, in this case 125ms
outer_loop:
delay_loop:
	adiw delay_reg1,1
	brne delay_loop
	dec mult_reg
	brne outer_loop
	ret
wait46:
	ldi mult_reg,3			;Determines pause length, in this case 46ms
outer_loop1:
delay_loop1:
	adiw delay_reg1,1
	brne delay_loop1
	dec mult_reg
	brne outer_loop1
	ret
	ldi delay_reg1, 255
    loop100:
    	nop
    	nop
    	nop
	dec delay_reg1
	brne loop100
	ret
BTW... the assembler gives me a warning about .def'ing registers 26-27... Says they are already defined(?). Is this something I should worry about?
Generally all you have to do set the initial location, the processor uses it for calls and returns and for pushes and pops. Your job is to make sure that it doesn't become 'unbalanced'. It gets unbalanced if you instruct the processor to jump out of a subroutine instead of exiting via the return instruction. It also gets unbalanced if you fall into a subroutine during sequential program execution instead of getting there via a call instruction. You can also unbalance the stack if you don't have an equal number of pushes and pops.
There are other uses for the stack but these are the ones you should be concerned with at this point.
Don
Have you looked at the contents of this file?
Don
The first thing I notice is after you clear the screen you don't wait before sending the string out. Check the datasheet for your display and wait that amount of time before issuing the next command.
How do you get here (in the latest version of your program)?
Don
Actually he does wait long enough, but I'm not sure he is aware of it. I alluded to this in a previous post concerning the sendcom routine.
Don
You code at string is confusing, I think you mean to point the Z register to string, but you skip past that. I think this is what you meant to do:
string:
print_string:
ps2:
   lpm
   tst r0
   mov data_reg, r0
   push zh
   push zl
   rcall senddat
   pop zl
   pop zh
   adiw zl,1
   rjmp ps2
string_finished:
   rjmp loop
I think our posts are overlapping and you may not have seen mine - I meant for him to figure this out by himself.
Don
Even if he got the Z register working, there's another error with the stack that would work in this example but would cause issues as the code was updated. Look at you original loop and notice how you push on to the stack and then test for end of string. If you branch out at this point, you never pop the data back off the stack, thus corrupting your stack. In this example you branch to an endless loop so you won't notice an error, but in the future when you actually use this routine as a subroutine and use ret to exit it, the stack won't be pointing to the return address. My changes also fix this.
floresta1212, dksmall, I love you guys.
Good job. Now go back and clean up your code. Make sure you understand what we have alluded to in our previous posts and ask more questions if you don't.
I haven't mentioned this before, but you are using what I call a shotgun approach for setting the data direction registers. You really shouldn't be dealing with the port pins that this program isn't using.
For your next assignment rewrite the program to have all of the I/O on one port.
Don
Don
Will keep that in mind, Don. I'm a total newb at this but I'm getting my bearings now.
This is the code that prints out "Hello LCD".
; LCD version 10
; Using Port A
; Printing String
.def data_reg = r24
.def mult_reg = r17
.equ data = porta
.equ dataDR = ddra
.equ rw = 7
.equ rs = 6
.equ enable = 5
;LCD codes
	rjmp main
main:
	out SPL, r16
	out SPH, r16
	ser r16
	out dataDR,r16
	out controlDR,r16
	clr r16
	out data,r16
	out control,r16
	rcall init
	;rcall sendcom
	;rcall sendcom
	rcall sendcom
	rcall sendcom
	rcall senddat
	ldi data_reg,'B'
	rcall senddat
	rcall wait1sec
	rcall clearLCD
	ldi r16,3			;Set cursor on third space
	rcall setcursor
	rcall print_string
	;rjmp loop
	;End MAIN
loop:
	rjmp loop
string:
print_string:
print_loop:
	; Print a character
	lpm
	tst r0
	mov data_reg, r0
	push zh
	push zl
	rcall senddat
	pop zl
	pop zh
	adiw zl,1
	rjmp print_loop
string_finished:
	ret
init:
	rcall wait125
	rcall first_pulse
	rcall first_pulse
	rcall first_pulse
	rcall wait46
	out data,r16
	nop
	rcall wait46
	rcall sendcom
	rcall sendcom
	rcall sendcom
	rcall sendcom
	;rcall sendcom
	ret
first_pulse:
	rcall wait125
	out data,r16
	nop
	nop
	ret
	rcall sendcom
	ret
setcursor:
	ldi r31,curs_pos1_com
	add r16,r31				;Add the spaces
	mov data_reg,r16
	rcall sendcom
	ret
	ser r16
	out dataDR,r16
	nop
	nop
	rcall wait46
	nop
	nop
	rcall wait46
	ret
	ser r16
	out dataDR,r16
	nop
	nop
	rcall wait46
	nop
	nop
	rcall wait46
	ret
LCD_busy:
check:
	sbic pina,7
	rjmp check
	ret
wait1sec:
outer_loop2:
delay_loop2:
	adiw delay_reg1,1
	brne delay_loop2
	dec mult_reg
	brne outer_loop2
	ret
wait125:
outer_loop:
delay_loop:
	adiw delay_reg1,1
	brne delay_loop
	dec mult_reg
	brne outer_loop
	ret
wait46:
outer_loop1:
delay_loop1:
	adiw delay_reg1,1
	brne delay_loop1
	dec mult_reg
	brne outer_loop1
	ret
	ldi delay_reg1, 255
    loop100:
    	nop
    	nop
    	nop
	dec delay_reg1
	brne loop100
	ret
of course, when will you have it done?
=D
Next question, why are you preserving the Z register before you call SendDat? I assumed you used it so I kept the push and pop instructions in your code fix. But a quick look at SendDat shows that the Z register is not used, so there's no need to push and pop that register.
And, if the contents of the Z register was destroyed by the sub-routine it makes sense that it is the called sub-routine that should push and pop it rather than the calling code. If not for anything else, this ensures that you only have to code for it once, no matter how many places you call it - so when you decide to change the subroutine (e.g. so that it destroys another registers content) you only need to change stuff in one place (rather than at n places where the subroutine is called).
In the demo that I linked to early in this thread, the code to output a string in flash is:
message_loop:
   lpm lcdData, Z+      ; Load from FLASH and increment pointer
   tst lcdData          ; End of string? (NUL character?)
   breq infinite_loop   ; Yes, bail out
   lcdChar
   rjmp message_loop    ; Next char
Notice that
i) No push/pop is done
ii) lpm can load into a designated register (the one that the character output subroutine wants it in)
iii) Z is auto-incremented
Why make it more convoluted than that?
I made a vertical scrolling version:
; LCD version 14
; Using Port A
; Scrolling Strings
.def data_reg = r24
.def mult_reg = r17
.equ data = porta
.equ dataDR = ddra
.equ rw = 7
.equ rs = 6
.equ enable = 5
;LCD codes
.equ curs_pos1_2line = 0b1100_0000
	rjmp main
main:
	out SPL, r16
	out SPH, r16
	ser r16
	out dataDR,r16
	out controlDR,r16
	clr r16
	out data,r16
	out control,r16
	rcall init
	rcall sendcom
	rcall sendcom
	ldi zh, HIGH(string*2)		;Print Hello LCD
	rcall print_string
	rcall wait1sec
	rcall wait1sec
	rcall clearLCD
	;ldi r16,3			;Set cursor on third space
	;rcall setcursor
	rjmp loop
	;End MAIN
loop:
	ldi zh, HIGH(string1*2)
	ldi zl, LOW(string1*2)
	rcall print_string
	ldi data_reg,curs_pos1_2line	;Cursor on second line
	rcall sendcom
	ldi zh, HIGH(string2*2)
	ldi zl, LOW(string2*2)
	rcall print_string
	rcall wait1sec
	rcall wait1sec
	rcall clearLCD
	rcall print_string
	rcall sendcom
	ldi zh, HIGH(string3*2)
	ldi zl, LOW(string3*2)
	rcall print_string
	rcall wait1sec
	rcall wait1sec
	rcall clearLCD
	rcall print_string
	rcall sendcom
	ldi zh, HIGH(string4*2)
	ldi zl, LOW(string4*2)
	rcall print_string
	rcall wait1sec
	rcall wait1sec
	rcall clearLCD
	rcall print_string
	rcall sendcom
	rcall print_string
	rcall wait1sec
	rcall wait1sec
	rcall clearLCD
	rjmp loop
string:
string1:
	.db "Hi, my name is",0x00
string2:
	.db "Slim Shady",0x00
string3:
	.db "Hi kids do you",0x00
string4:
	.db "like violence?",0x00
; Print String
; MUST set z with the string you want to print FIRST
print_string:
	;ldi zh, HIGH(string*2)
	;ldi zl, LOW(string*2)
print_loop:
	; Print a character
	lpm
	tst r0
	mov data_reg, r0
	push zh
	push zl
	rcall senddat
	pop zl
	pop zh
	adiw zl,1
	rjmp print_loop
string_finished:
	ret
init:
	rcall wait125
	rcall first_pulse
	rcall first_pulse
	rcall first_pulse
	rcall wait46
	out data,r16
	nop
	rcall wait46
	rcall sendcom
	rcall sendcom
	rcall sendcom
	rcall sendcom
	;rcall sendcom
	ret
first_pulse:
	rcall wait125
	out data,r16
	nop
	nop
	ret
	rcall sendcom
	ret
setcursor:
	mov data_reg,r16
	rcall sendcom
	ret
	ser r16
	out dataDR,r16
	nop
	nop
	rcall delay5msec
	nop
	nop
	rcall delay5msec
	ret
	ser r16
	out dataDR,r16
	nop
	nop
	rcall delay5msec
	nop
	nop
	rcall delay5msec
	ret
LCD_busy:
check:
	sbic pina,7
	rjmp check
	ret
wait1sec:
outer_loop2:
delay_loop2:
	adiw delay_reg1,1
	brne delay_loop2
	dec mult_reg
	brne outer_loop2
	ret
wait125:
outer_loop:
delay_loop:
	adiw delay_reg1,1
	brne delay_loop
	dec mult_reg
	brne outer_loop
	ret
wait46:
outer_loop1:
delay_loop1:
	adiw delay_reg1,1
	brne delay_loop1
	dec mult_reg
	brne outer_loop1
	ret
	ldi delay_reg1, 255
    loop100:
    	nop
    	nop
    	nop
	dec delay_reg1
	brne loop100
	ret
delay5msec:		; 80 * 4 * 255 =~ 80000 cycles
	ldi delay_reg1, 80
    outerloop2:
	ldi delay_reg2, 255
    innerloop2:
	dec delay_reg2
	nop
	brne innerloop2
	dec delay_reg1
	brne outerloop2
	ret
Sorry if anyone here doesn't like Eminem... but that's how I felt at times trying to do this in asm =D
Pages
