Error on array initialisation
5 posts / 0 new
I using external SDRAM on EVK1100 and I have problem when try to initialize array as :
__attribute__((__section__(".data_sdram"))) static U16 array[2] = {1,2};
and
__attribute__((__section__(".data_sdram"))) static U16 var = 1;
working well.
I have thinking about a compiler option problem and try :
by using internal SRAM, working well.
Then, may be there is something to add in the linker script but I don't know what. My script right now is :
MEMORY
    SDRAM (wxa!ri) : ORIGIN = 0xD0000000, LENGTH = 0x02000000
PHDRS
    SDRAM_AT_FLASH PT_LOAD;
    SDRAM PT_NULL;
SECTION
    . = ORIGIN(SDRAM);
    .data_sdram     ORIGIN(SDRAM) :
     PROVIDE(_data_sdram = .);
     *(.data_sdram)
     . = ALIGN(8);
     PROVIDE(_edata_sdram = .);
    } >SDRAM AT>SDRAM :SDRAM_AT_FLASH
    PROVIDE(_data_sdram_lma = ABSOLUTE(LOADADDR(.data_sdram)));
If somebody have an idea ... I'm not blocked as I can use the internal SRAM but I prefer using SDRAM for all variables.
cpu
Sure about that, it will kill some performance? I would store often accessed variables and the stack in internal RAM, and use the external RAM for buffers and heap.
Hans-Christian
Hi hce,
As I haven't performance problem, I have all variables in SDRAM but let the heap and stack in SRAM. It's enough fast for my use. In addition, arrays are temporary buffers as huge matrix hard coded. :(
Hope later this will be changed ...
cpu
Not actually helping you to solve your issue, but are the matrices constant variables? Or do you perform calculations on them?
If they are read-only you could keep them in flash, just add the "const" word when defining the variables.
Hans-Christian
In fact, arrays are really temporary, then after I put matrix as const in NVRAM in the initialization phase.
Just I need a system to fill matrix hard coded and then put them in NVRAM where access will be only read.
Thanks for your help, but I think I will let array in SRAM, statical in a function as I will retrieves my complete SRAM after this init phase.
cpu
