Setting up timer for ADC conversion trigger
3 posts / 0 new
I've been working with the ATMEGA324P-20AU to read some data over SPI from five ADCs that are triggered (all at the same time) by a conversion pin. The conversion pin of each ADC is wired to one pin of the ATMEGA.
I would like to have the ATMEGA trigger each conversion at an adjustable rate between 1 Hz and 1 kHz. The conversion rate is adjustable in software. I would like to achieve at least 0.1 Hz resolution.
I've noticed that the ATMEGA324P-20AU has an external pin (TOSC1) that can accept an input from an external oscillator.
If I am to use the 16-bit timer of the AVR, and the main processor clock is 18.432 MHz, could someone suggest:
(1) The clock frequency that I should input to the TOSC1 pin using an external oscillator.
(2) Which pin should I use as the conversion pin for the ADCs? One of the OCnA or OCnB pins?
Those rates are fairly slow (in microcontroller terms). Merely use one of the AVR's timers to "trip" between 1ms and 1000ms, and do the work in a simple ISR. 16-bit timer1 will have more "reach" and perhaps make the code simpler.
No need for an external clock for this purpose.
That sounds good; thank you very much for pointing me in the right direction, theusch! I am more familiar with simple ISRs than with the use of an external clock, and I agree that this will make the code much simpler.
