how to do this using pointer? (codevision avr)
thank :)
how copy int to char[2] using pointer?
you can use union
union i2c
char c[2];
int i;
please show example how convert value 0xefda to c[2]
At least 3 ways I can think of.
1) Union, as mentioned
2) Explicit memcpy
3) Implicit memcpy, using a casted pointer
At least 3 ways I can think of.1) Union, as mentioned
2) Explicit memcpy
"There must be 50 ways to love your lever..."
(we don't know the byte order, nor why one might want to send arbitrary "int" values--does OP really want itoa()? [see https://www.avrfreaks.net/index.p... ] is the data really signed?)
4) c[0] = (unsigned char)i; c[1] = (unsigned char)((unsigned int)i >> 8);
char c[2];
c[0] = (char)(0xefda & 0xff);
c[1] = (char)((0xefda >> 8 )&0xff);
--------------------------------or-------------
int i = 0xefda;
char c[2];
char *pc;
pc = &c[0];
*pc = (char)(i & 0xff);
pc++;
*pc = (char)((i >> 8 )& 0xff);
char* itoa( int __val, char * __s, int __radix )
The function itoa() converts the integer value from val into an ASCII representation that will be stored under s. The caller is responsible for providing sufficient storage in s.
Note:
The minimal size of the buffer s depends on the choice of radix. For example, if the radix is 2 (binary), you need to supply a buffer with a minimal length of 8 * sizeof (int) + 1 characters, i.e. one character for each bit plus one for the string terminator. Using a larger radix will require a smaller minimal buffer size.
Warning:
If the buffer is too small, you risk a buffer overflow.
Conversion is done using the radix as base, which may be a number between 2 (binary conversion) and up to 36. If radix is greater than 10, the next digit after '9' will be the letter 'a'.
If radix is 10 and val is negative, a minus sign will be prepended.
The itoa() function returns the pointer passed as s.
@pardhu4poori
I'm pretty sure the OP is not looking for a printable string representation of the integer, since two chars will not suffice for this.
Rather, it seems his question is "how to split a (16-bit) integer into two (8-bit) chars?".
Suppose you have an integer, you can declare a pointer to an array of 2 char:
int my_int; char (*my_array_p)[2]; ... // then inside main my_int=0xABCD; // give a value to the integer my_array_p= &my_int // assign the address of my_int //to read you have to do: (*my_array_p)[0]; //low byte (0xCD) (*my_array_p)[1]; //high byte (0xAB)
if you want to copy the contents to another char array
char my_array[2]; my_array[0]=(*my_array_p)[0]; my_array[1]=(*my_array_p)[1];
Be careful how you declare and how you read the pointer,they should be the same as my example.
char (*my_array_p)[2]; // this is a pointer to an array of 2 char
char *my_array_p[2]; // this is an array of 2 char pointers
Alex
char c[2];int i = 0xefda;
char c[2];
char *pc;
pc = &c[0];*pc = (char)(i & 0xff);
pc++;
this has the same result as
int i = 0xefda; char c[2]; char *pc; pc=&i; c[0]=*pc; pc++; c[1]=*pc;
but you will get a few warnings from the compiler,
assuming you know what you are doing you can ignore them.
Alex
int ival; int * p_ival; char c[2]; p_ival = (int *)c; // (int *)&c[0] is more explicit *p_ival = ival;
This is the implicit memcpy using a casted pointer that I mentioned before.
