GCC Through AVRStudio Problem
7 posts / 0 new
Hi all ,
I've got a problem with GCC project through AVRStudio
When tested with CodeVision , everything was allright
With GCC I can't see anything on HyperTerminal
1)It seems printf doesn't work and
2)Time_Cnt variable ,
is not correctly accepted as a global variable.
I use AVRStudio 4.18 & CodeVision 2.04.4a .
I've shortened the codes and they are attached .
best regards.
Here is The GCC Code
#include
#include
#include
#define  Timer1_INT_Dis     TIMSK  = 0x00;
#define  Timer1_INT_En      TIMSK  = 0x04;
void Init_USART(void);
void Init_Timer1(void);
unsigned char Tim1_Delay(unsigned int delay);
unsigned int Time_Cnt;
int main()
	Init_Timer1();
	Init_USART();
	sei();
	printf("start...");
	Tim1_Delay(100);
	UDR='A';
    Tim1_Delay(100);
	UDR='B';
	Timer1_INT_Dis;
		UDR='C';
void Init_USART(void){
    // USART initialization
    // Communication Parameters: 8 Data, 1 Stop, No Parity
    // USART Receiver: On
    // USART Transmitter: On
    // USART Mode: Asynchronous
    // USART Baud Rate: 9600
    UCSRA=0x00;
    UCSRB=0x18;
    UCSRC=0x86;
    UBRRH=0x00;
    UBRRL=0x4D;
	Time_Cnt=0;
    Timer1_INT_En;
	do{
    }while(Time_Cnt < delay);
	Timer1_INT_Dis;
    return 0;
//TIMER1 INITIALIZATION
    cli();
	TCCR1A=0x00;
    TCCR1B=0x04;
    //TCNT1 =(65536 - (1*12000000)/ 256000);//1ms
	TCNT1H=0xff;
    TCNT1L=0xef;
    ICR1H=0x00;
    ICR1L=0x00;
    OCR1AH=0x00;
    OCR1AL=0x00;
    OCR1BH=0x00;
    OCR1BL=0x00;
	Timer1_INT_Dis;
ISR(TIMER1_OVF_vect)
	TCNT1H=0xff;
	TCNT1L=0xef;
	Time_Cnt++;
And Here is The CodeVision Code
#include
#include
void main(void)
    Init_Timer1();
    Init_USART();
    #asm("sei")
    printf("start...");
    Tim1_Delay(100);
    UDR='A';
    Tim1_Delay(100);
    UDR='B';
    Timer1_INT_Dis;
        UDR='C';
    UCSRA=0x00;
    UCSRB=0x18;
    UCSRC=0x86;
    UBRRH=0x00;
    UBRRL=0x4D;
    Time_Cnt=0;
    Timer1_INT_En;
    do{
    Timer1_INT_Dis;
    return 0;
    #asm("cli");
    TCCR1A=0x00;
    TCCR1B=0x04;
    TCNT1H=0xff;
    TCNT1L=0xef;
    ICR1H=0x00;
    ICR1L=0x00;
    OCR1AH=0x00;
    OCR1AL=0x00;
    OCR1BH=0x00;
    OCR1BL=0x00;
    Timer1_INT_Dis;
interrupt[TIM1_OVF] void TIM1_OVF_interupt(void)
    TCNT1H=0xff;
    TCNT1L=0xef;
    Time_Cnt++;
Both programs are seriously wrong.
You should only write to UDR when the USART has space in its buffer (UDRE bit is set)
avr-gcc needs FDEV_xxx() macros before you an use printf()
CodeVision can use prinf() immediately.
Having got your functions 'associated' with the USART, just use putchar(). Never touch UDR at all.
avr-gcc will not know that Time_Cnt ever alters. Declare it volatile.
If you want an accurate timer, use the CTC mode.
In your case you might just as well use delay_ms() or _delay_ms(). i.e. you are just wasting time, and doing nothing else.
Suggest you start by reading the GCC user manual.
Bottom line is that by default Codevision has the putchar() that printf() uses connected to a UART_putchar() routine. In GCC this connection is not made automatically by default. It's up to you, the programmer to make the connection.
As GCC comes from a Linux heritage then all output is done via "file streams". So you need to setup a file stream that connects to a UART output routine and then connect that file stream to "stdout" which is the standard file stream that GCC programs use for output.
So try something like:
#include
#include
#include
int uart_putc(char c, FILE *unused) {
#ifdef __AVR_ATmega168__
	while (!(UCSR0A & (1<<UDRE0)));
	UDR0 = c;
#else
	while (!(UCSRA & (1<<UDRE)));
	UDR = c;
#endif
	return 0;
FILE uart_str = FDEV_SETUP_STREAM(uart_putc, NULL, _FDEV_SETUP_WRITE);
int main()
   Init_Timer1();
   Init_USART();
   stdout = &uart_str; // printf to UART
   sei();
   printf("start...");
   Tim1_Delay(100);
   UDR='A';
    Tim1_Delay(100);
   UDR='B';
   Timer1_INT_Dis;
      UDR='C';
    UCSRA=0x00;
    UCSRB=0x18;
    UCSRC=0x86;
    UBRRH=0x00;
    UBRRL=0x4D;
   Time_Cnt=0;
    Timer1_INT_En;
   do{
   Timer1_INT_Dis;
    return 0;
    cli();
   TCCR1A=0x00;
    TCCR1B=0x04;
   TCNT1H=0xff;
    TCNT1L=0xef;
    ICR1H=0x00;
    ICR1L=0x00;
    OCR1AH=0x00;
    OCR1AL=0x00;
    OCR1BH=0x00;
    OCR1BL=0x00;
   Timer1_INT_Dis;
   TCNT1H=0xff;
   TCNT1L=0xef;
   Time_Cnt++;
To understand how that works read this page in the user manual:
BTW change your while(1) to call:
uart_putc('C', NULL);
Thanks a lot ,
added the word volatile , the timer is accurate now .
And astonishingly printf is working properly .
With your help , both of my problems were solved .
BTW, Sorry , I just used UDR in that way to simply show my problem .
When I see some really useful guys like david.prentice and clawson ,
I get ashamed .
What a nightmare is my life !
When accessing 16 bit registers, let the compiler do the heavy lifting and save yourself some time. Ex:
    TCNT1H=0xff;
    TCNT1L=0xef;
Naw, man !
TCNT1=0xFFEF;
Yea, man !!
2) WinAvr 20100110
A) Avr Dragon ver. 1
B) Avr MKII ISP, 2009 model
C) MKII JTAGICE ver. 1
Did you buy it or got a cracked copy? :roll:
    TCNT1H=0xff;
    TCNT1L=0xef;
Naw, man !
TCNT1=0xFFEF;
Yea, man !!
As I said these codes were just for test .
It worked with CodeVision and that was enough .
BTW,I intentionally added the comment below :
"//TCNT1 =(65536 - (1*12000000)/ 256000);//1ms"
Yea, man !!
As you know , cracked one . [then this goes no further - moderator (CJL)]
Topic locked
