Can't debug on meshnetics board
6 posts / 0 new
Hi folks,
Would anybody here be able to tell me why I can't place breakpoints in this project. It's the ZBNDemo that came with the meshnetics kit. Micro is ATmega1281. Using a jtag mkii and it works fine except for debugging with breakpoints... I'm assuming it's something to do with optimization in the makefile (below) but I don't really know my way around these files... Thanks in advance.
Phil
PROJNAME = ZBNDemoApp
PROJECT  = $(PROJNAME).elf
# Select the stack type and the security mode
SECURITY_MODE = NO_SECURITY
#SECURITY_MODE = STD_SECURITY
STACK_TYPE = ZBN_ALL
#STACK_TYPE = ZBN_COORDINATOR
#STACK_TYPE = ZBN_ROUTER
#STACK_TYPE = ZBN_ENDDEVICE
# Automatic selection of Makerules and related parameters
ifeq ($(STACK_TYPE), ZBN_ALL)
ifeq ($(SECURITY_MODE), NO_SECURITY)
include ../../ZigBeeNet/lib/MakerulesZbnAll
endif
ifeq ($(SECURITY_MODE), STD_SECURITY)
include ../../ZigBeeNet/lib/MakerulesZbnAllStdSec
endif
endif
ifeq ($(STACK_TYPE), ZBN_COORDINATOR)
include ../../ZigBeeNet/lib/MakerulesZbnCoordinator
endif
include ../../ZigBeeNet/lib/MakerulesZbnCoordinatorStdSec
endif
endif
ifeq ($(STACK_TYPE), ZBN_ROUTER)
include ../../ZigBeeNet/lib/MakerulesZbnRouter
endif
include ../../ZigBeeNet/lib/MakerulesZbnRouterStdSec
endif
endif
ifeq ($(STACK_TYPE), ZBN_ENDDEVICE)
include ../../ZigBeeNet/lib/MakerulesZbnEndDevice
endif
include ../../ZigBeeNet/lib/MakerulesZbnEndDeviceStdSec
endif
endif
# COMPILER FLAGS --------------------------------------
#CFLAGS += -Os
CFLAGS += -Wl,--gc-sections
# Application paramters
CFLAGS += -DTIMER_SENDING_PERIOD=3000
#After this amount of failed transmission in a row the rejoin network procedure is done
CFLAGS += -DTHRESHOLD_FAILD_TRANSMISSION=10
# Stack paramters being set to Config Server
CFLAGS += -DCS_AUTONETWORK=1
# If CS_AUTONETWORK is 1 CS_CHANNEL_MASK should be declared
CFLAGS += -DCS_CHANNEL_MASK=0x01000000
CFLAGS += -DCS_EXT_PANID=0xAAAAAAAAAAAAAAAALL
CFLAGS += -DCS_END_DEVICE_SLEEP_PERIOD=5000
CFLAGS += -DCS_NEIB_TABLE_SIZE=7
CFLAGS += -DCS_MAX_CHILDREN_AMOUNT=6
CFLAGS += -DCS_MAX_CHILDREN_ROUTER_AMOUNT=2
CFLAGS += -DCS_ROUTE_TABLE_SIZE=30
CFLAGS += -DCS_ADDRESS_MAP_TABLE_SIZE=10
CFLAGS += -DCS_ROUTE_DISCOVERY_TABLE_SIZE=10
CFLAGS += -DCS_APS_DATA_REQ_BUFFER_SIZE=3
CFLAGS += -DCS_APS_ACK_FRAME_BUFFER_SIZE=2
CFLAGS += -DCS_DUPLICATE_REJECTION_TABLE_SIZE=5
# The value of polling should be less than CS_ACK_TIMEOUT
# by default the value is a one half of CS_ACK_TIMEOUT
#CFLAGS += -DCS_INDIRECT_POLL_RATE=1000
# Used only for static addressing
#CFLAGS += -DCS_NWK_ADDR=0x0001
#CFLAGS += -DCS_NWK_UNIQUE_ADDR=true
# Pre-configured key which is used by NWK
#CFLAGS += -DCS_NETWORK_KEY="{0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC,0xCC}"
#0 - preconfigured network key
#1 - preconfigured trust centre link key
#2 - preconfigured trust centre master key
#3 - not preconfigured
CFLAGS += -DCS_ZDO_SECURITY_STATUS=3
#CFLAGS += -DCS_UID=0xAAAAAAAAAAAAAAAALL
CFLAGS += -DCS_APS_TRUST_CENTER_ADDRESS=0xAAAAAAAAAAAAAAAALL
#CFLAGS += -DCS_APS_SECURITY_TIMEOUT_PERIOD=10000
# COMPONENTS PATHS ---------------------------------------
STACK_PATH = ../../ZigBeeNet/Components
ifeq ($(HAL), ATMEGA1281)
  HAL_PATH = $(STACK_PATH)/HAL/atmega1281
endif
ifeq ($(HAL), ATMEGA2561)
endif
ifeq ($(HAL), AT91SAM7X256)
  HAL_PATH = $(STACK_PATH)/HAL/at91sam7x256
endif
BSP_PATH = $(STACK_PATH)/BSP
MAC_PATH = $(STACK_PATH)/MAC_PHY
NWK_PATH = $(STACK_PATH)/NWK
APS_PATH = $(STACK_PATH)/APS
ZDO_PATH = $(STACK_PATH)/ZDO
PDS_PATH = $(STACK_PATH)/PersistDataServer
TC_PATH  = $(STACK_PATH)/Security/TrustCentre
SSP_PATH  = $(STACK_PATH)/Security/ServiceProvider
SE_PATH  = $(STACK_PATH)/SystemEnvironment
CS_PATH  = $(STACK_PATH)/ConfigServer
APP_PATH = .
# INCLUDES PATHS FLAGS ----------------------------------
INCLUDEDIRS =                          \
	-I./include                          \
	-I$(SE_PATH)/include                 \
	-I$(APS_PATH)/include                \
	-I$(NWK_PATH)/include                \
	-I$(ZDO_PATH)/include                \
	-I$(MAC_PATH)/include                \
	-I$(HAL_PATH)/HAL_HWD/include        \
	-I$(HAL_PATH)/HAL_HWI/include        \
	-I$(BSP_PATH)/include                \
	-I$(CS_PATH)/include                 \
	-I$(PDS_PATH)/include                \
	-I$(TC_PATH)/include                 \
	-I$(SSP_PATH)/include
# LIB PATHS FLAGS ----------------------------------------
LIBDIRS = -L$(APP_PATH)/../../ZigBeeNet/lib -L$(BSP_PATH)/lib
# LIBRARIES ----------------------------------------------
LIBS = -l$(STACK_LIB) -lBSP
# OBJECTS ------------------------------------------------
objects =                                     \
  $(APP_PATH)/objs/ZBNDemoApp.o               \
  $(APP_PATH)/objs/ZBNCoord.o                 \
  $(APP_PATH)/objs/ZBNRouter.o                \
  $(APP_PATH)/objs/ZBNEndDevice.o             \
  $(APP_PATH)/objs/ZBNUARTManager.o           \
  $(APP_PATH)/objs/ZBNSensorManager.o         \
  $(CS_PATH)/objs/ConfigServer.o              \
  $(PDS_PATH)/objs/pdsCrcService.o            \
  $(PDS_PATH)/objs/pdsDataServer.o            \
  $(PDS_PATH)/objs/pdsWriteData.o
#  TARGETS ------------------------------------------------
all: $(objects) $(PROJECT) $(PROJNAME).srec $(PROJNAME).hex
$(objects):
	$(CC) $(CFLAGS) $(INCLUDEDIRS) -c $^ -o $@
$(APP_PATH)/objs/ZBNDemoApp.o:       $(APP_PATH)/ZBNDemoApp.c
$(APP_PATH)/objs/ZBNCoord.o:         $(APP_PATH)/ZBNCoord.c
$(APP_PATH)/objs/ZBNRouter.o:        $(APP_PATH)/ZBNRouter.c
$(APP_PATH)/objs/ZBNEndDevice.o:     $(APP_PATH)/ZBNEndDevice.c
$(APP_PATH)/objs/ZBNUARTManager.o:   $(APP_PATH)/ZBNUARTManager.c
$(APP_PATH)/objs/ZBNSensorManager.o: $(APP_PATH)/ZBNSensorManager.c
$(CS_PATH)/objs/ConfigServer.o:      $(CS_PATH)/src/configServer.c
$(PDS_PATH)/objs/pdsCrcService.o:    $(PDS_PATH)/src/pdsCrcService.c
$(PDS_PATH)/objs/pdsDataServer.o:    $(PDS_PATH)/src/pdsDataServer.c
$(PDS_PATH)/objs/pdsWriteData.o:     $(PDS_PATH)/src/pdsWriteData.c
$(PROJECT): $(objects) Makefile
	$(CC)  $(objects) $(HAL_PATH)/lib/WdtInit.o $(CFLAGS) $(INCLUDEDIRS) $(LIBDIRS) $(LIBS) -lm -o $(PROJECT)
	$(SIZE) -td $(PROJECT)
$(PROJNAME).srec:
	$(OBJCOPY) -O srec --srec-len 128 $(PROJECT) $(PROJNAME).srec
$(PROJNAME).hex:
	$(OBJCOPY) -O ihex $(PROJECT) $(PROJNAME).hex
#burn:
#	avarice -2epf ${TARGET} -j /dev/ttyS0
## Clean target
clean:
	-rm -rf $(TARGET) $(objects) $(PROJECT) $(PROJNAME).hex $(PROJNAME).eep $(PROJNAME).srec $(APP_PATH)/lib/*.*
Try adding a -g (or better -gdwarf-2) to the CFLAGS which embeds symbolic debug info into the ELF that you debug.
Thanks for the tip, I'm certain that it'll come in handy :)
Should anyone else wish to know; the problem turned out to be with a space in a directory name...
Yup, unless you are willing to go through and "" quote all paths in Makefiles, you'll find GCC gets on much better with plain pathnames.
Are you sure you want to mess with some REALLY outdated code? Why not download new SDK from Atmel site?
Hi Alex,
Thanks for pointing that out. After the same other issues with the Atmel SDK (now fixed) I went back to the meshnetics stuff. This problem was evident in both and the makefile from meshnetics seemed more complete...
Still, I'm now using the Atmel WSNDemoApp as a starting point and slowly learning my way around this makefile business to boot. I'vee been putting it off for far too long...
