How to get information about program size in Flash
5 posts / 0 new
Does anybody know how to get information about application size in flash and ram usage information?
Best regards
Michael
Hi Michael,
Are you using GCC? If so, you can tell the linker to produce a linker map file. I did it by going to the linker settings in avr32studio. Then select "Miscellaneous". Then add the following two things to "Other options (-Xlinker [option])" in separate lines:
--Map
WHATEVER_YOU_WANT_THE_LINKER_FILE_NAME_TO_BE
gcc will pass these to the linker and it will produce a linker map file.
-jon
Thank you for the fast response.
I tested the -map switch a map file was generated.
Unfortunally it was not so usefull no map summary has been given.
My mplab compiler uses also gcc it produce a usefull summary at the end of linker process.
What do you mean it wasn't useful? Its a bit complicated so you have to parse it to get the exact information you need.
You can also use avr32-size to get the summary for the various sections.
Hans-Christian
