max232 Heating like hell!
9 posts / 0 new
I have started using smt components oflate. I am having a problem with my max232 ICs. They seem to over heat up nearly like a short circuit condition.
I feel the unused port is creating a problem and causing the charge pumps to overheat. Any idea what do i do to the unused inputs(pull down to GND or pull up to Vcc)
Never had this problem with the normal DIP ICs
Thanks Rodney
Unused inputs are pulled high by internal resistors, IIRC. You've connected them wrong if they are getting hot.
Leon
Leon Heller G1HSM
If you are using polarized caps in the charge pump, make sure they care installed correctly. Check your + and - voltages on the chip. You should have approx +10V on pin2 and approx -10V on pin6 if you run it from 5V.
Check, also, that no RS232 transmit pin (pin 7 & 14) is shorted to ground.
I have never had problems leaving the unused channel un-terminated on either the logic side or the RS232 side.
using non polorised chip capacitors. I have changed the ic and using a max3232 which is pin compatible. had to change the caps to 100nf too. seems fine for now.
Are you sure there is no short circuit in your pcb design?
Michael.
User of:
IAR Embedded Workbench C/C++ Compiler
Altium Designer
There are no shorts. was getting this problem on a couple of circuits. after changing to max3232 no problems.
The current version of the MAX232E data sheet states: "Transmitter input pull-up resistors, enable, and shutdown are not provided on the ... and MAX232E." on Figure 3.
http://datasheets.maxim-ic.com/e...
I once failed to communicate with a MAX232ECPE. Problem was fixed when I connected the unused inputs simply in parallel with the used inputs. I guess the unused inputs were oscillating and brought the charge pump down.
I don't remember the chip heating, but then again I probably didn't touch it much.
- Simo
I m using MAX3232(SMD)with ATMEGA32. It gets heated very much (untouchable). I have not been able to find out the reason.
CAN sending too much data heat the MAX3232?
PLease can anyone help me???
I very much doubt it ... check the polarity and connections of your charge caps.
