What's this system/circuit called? [debunked]
7 posts / 0 new
[EDIT: This doesn't work. Do not read!]
What is this circuit called? Seems to be a simple way to output a sine wave, so it must have some standard name. I couldn't find it in The Art of Electronics, probably because I don't know what to look for...
note: ATtiny can be any PWM generator (ie: 555's, etc.)
Its called Lowpass FIltered PWM, or any similar name you would like to attach to it.
I would not call the output "beat frequency" because that implies two signals into a mixer (in the RF sense- as in "multiplier", not the audio sense), looking at the difference component. Similarly, it is not inherently a sine generator; you can use it for (almost) any continuous, single-valued, periodic waveform you like. Come to think of it, it does not even have to be periodic; you can generate a random sequence (ie, "noise") which I guess will really be pseudo-random and then quasi-periodic.
Jim,
do you think adjective "balanced" could be used when describing the above circuit?
The way it is drawn suggests "balanced". If the PWM modulation is balanced, then it would function as balanced, whether the PWM signals are exactly balanced/complementary or not.
I am not sure balanced mode would help much of anything unless the load requires balanced input.
The word "differential" comes to my mind before the word "balanced" does.
Agree!
Right; PWM is an incorrect term. I'm thinking of a 50% pulse train with no width modulation (not balanced, either). Maybe that's why my "PWM beat" searches didn't find what I was looking for. Also, this circuit will only make an [beat frequency] envelope, roughly modulated at pulse frequencies. Like this:
Guess I need a few more knocks to the forehead. Thanks Jim!
SPICE (MacSpice) code to generate the above:
[Not A] Simple Differential RC Sine Wave Generator
Vp1	1 0		0 PULSE(0 5 5ns 5ns 5ns 99us 198us)
Vp2	2 0		0 PULSE(0 5 5ns 5ns 5ns 101us 202us)
R1	1 3		220
R2	2 4		220
C1	3 4		100nF
.control
delete all
op
tran 50ns 30ms 10ms
plot v(3, 4)
.endc
.END
