Good day!
Sorry for posting Arduino-related questions here and not on Arduino forum, but I haven't get any responses on Arduino forum about this (on other topics I get fast and accurate responses, thanks, Arduino community!). This seems to be more general AVR\avrdude related (it seems I'm coming clother and clother to bare WinAVR :))
I'm trying to burn a Arduino bootloader into blank Atmega8A-PU using Arduino Duemilanove (Atmega328P) as ISP programmer (with ArduinoISP sketch). The target configuration is with internal RC oscillator at 8Mhz.
Here is the wiring: http://arduino.cc/en/uploads/Tut...
The bootloader comes from here: http://todbot.com/blog/2009/05/2...
(The same as original, just changed for 8Mhz), but it seems I haven't get so far to burn bootloader.
Here are settings from boards.txt (to illustrate fuses and lockbits):
############################################################## atmega8noxtal.name=ATmega8-noxtal @8MHz atmega8noxtal.upload.protocol=stk500 atmega8noxtal.upload.maximum_size=7168 atmega8noxtal.upload.speed=38400 atmega8noxtal.bootloader.low_fuses=0xe4 atmega8noxtal.bootloader.high_fuses=0xc4 atmega8noxtal.bootloader.path=atmega8_noxtal atmega8noxtal.bootloader.file=ATmegaBOOT.hex atmega8noxtal.bootloader.unlock_bits=0x3F atmega8noxtal.bootloader.lock_bits=0x0F atmega8noxtal.build.mcu=atmega8 atmega8noxtal.build.f_cpu=8000000L atmega8noxtal.build.core=arduino
I've enabled detailed messages in Arduino IDE to see exact avrdude options. It seems it first run avrdude to write fuses and lock bits.
I've tried to update avrdude to the latest version (version is visible below) as described here: http://letsmakerobots.com/node/2...
Here is an error:
C:\Tools\arduino\hardware/tools/avr/bin/avrdude -CC:\Tools\arduino\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega8 -cstk500v1 -P\\.\COM10 -b19200 -e -Ulock:w:0x3F:m -Uhfuse:w:0xc4:m -Ulfuse:w:0xe4:m avrdude: Version 5.10, compiled on Jan 19 2010 at 10:45:23 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2009 Joerg Wunsch System wide configuration file is "C:\Tools\arduino\hardware/tools/avr/etc/avrdude.conf" Using Port : \\.\COM10 Using Programmer : stk500v1 Overriding Baud Rate : 19200 [...skip...] avrdude: Device signature = 0x0000ff avrdude: Expected signature for ATMEGA8 is 1E 93 07 Double check chip, or use -F to override this check.
Sometimes I get this:
avrdude: Device signature = 0x8133ff avrdude: Expected signature for ATMEGA8 is 1E 93 07 Double check chip, or use -F to override this check. avrdude: Send: Q [51] [20]
or this:
avrdude: Device signature = 0xffffff avrdude: Yikes! Invalid device signature. Double check connections and try again, or use -F to override this check.
Is chip brokent\locked?
May be I've erased the signature in some way (as described here: http://www.arduino.cc/cgi-bin/ya...)?
Thanks in advance!
