sleep and ATtiny15
5 posts / 0 new
Hello fellow freaks,
I am working on a simple remote control, which should use the sleep instruction. After a interrupt, it should wake up, send some code via IR, return from the interrupt and enter sleep-mode again.
Somehow, my attiny15 does not seem to wake up after a external irq. Anyone had this problem before or does seem familiar to?
Thanks in advance and a happy new year for now!
Marc
structure program is kinda like this:
setup mcu for power down mode, but do not enable the sleep mode
setup all other stuff for mcu
main program:
enable sleep
go to sleep
delay of 512 ms
rjmp to begin main program
irq:
send code
do you have a code ? maybe it's the INT vector (wrong position or not programmed?) ATtiny15 don't need stack setup.
admin's test signature
Include the setup for the sleep (MCUCR) at least.
Are you using level-triggered interrupts? It will not wake up from an edge-triggered interrupt in the lowest power sleep mode, but only from a relatively sustained "low" input.
Sean.
Hey everyone,
finally got to a computer again with internet..
I have solved it after writing code segments, adding functions one at a time. It turned out to be the way the ext-irq was generated (I first used levelchange irq, it has to be low level irq, as noted by Sean).
I also had some trouble not getting back to sleep after the execution of the irq, but that had to do with the way I turned the PWM on and off, and the delays before an out- command becomes effective. Solved that too though :)
Thanks everyone for your help!
Marc
