JTAG with multiple ATMEGA64
6 posts / 0 new
Hello all,
has anyone experience with emulating more than one ATMEGA in a JTAG chain?
I use 5 pcs. of ATMEGA 64 in a JTAG-chain. Now I want to debug these controllers (one after another) with the ATJTAGICE. In the AVRSTudio I can set any options (Debug / JTAG ICE Options / Connection). There I can check the box "Target device is part of a JTAG daisy chain". If I activate this option I have to define 4 values about the devices before and after my target and about the instructions bits before and after. Here is my problem. I have only 5 ATMEGAs in the JTAG chain. But what are the values for the the instruction bits febore and after? I cannot found any hint in the datasheet. Can anyone help me??
Thank you very much for your help. With best regards and the best wishes for a good and peaceful year 2004!
Winfried
admin's test signature
There are 4 instruction bits per device, so if you want to talk to your third device you write 8 instruction bits before and 8 after.
-Geir
I am trying to do something very similar with two Mega32's but I don't understand how this chain is connected, does the TDO from the first device to the TDI of the second and the loop forms like that?
If so is it possible to have two instances of AVR Studio open at the same time, I am trying to debug an interface between the two controllers and finding it a pain to have access to separate JTAGs at the same time.
That's the way multi-JTAG normally works - it's a line of shift registers effectively. If you want to get the data from B then you have to say how many clocks are needed to shift A's data out of the way first.
Cliff
I haven't done such a thing yet. But I'm interested. Is there still a possibility to program the avrs in a multi part jtag chain? Also with different parts mixed (e.g. atmel + altera)?
