Simulator and ATmega48 Stack Pointer
3 posts / 0 new
Using the AVR simulator II, at reset the stack pointer is 0x4FF (correct). After my code, it is 0xFF. TEMP register shows correct values.
What am I missing?
RESET:							;
	cli							;NO INTERRUPTS
	in TEMP, MCUCR				;
	mov saveMCUCR, TEMP			; Store MCUCR for future reference in debug
	ldi TEMP, 0x00				;
	out MCUCR, TEMP				; Reset MCUCR flags
	ldi TEMP, high(RAMEND)	;Set stack pointer to the end of memory
							;  S/B 0x04
	out SPH, TEMP			;
	ldi TEMP, low (RAMEND)	;  S/B 0xFF
	out SPL, TEMP			;RAMEND S/B 0x02FF
							; simulator SP = Xx00FF
John
0x4FF is not correct - 0x2FF is. When I build and run this in the simulator 2:
	.include "m48def.inc"
	.def	TEMP = R16
	.def	saveMCUCR = R17
RESET:                     ;
   cli                     ;NO INTERRUPTS
   in TEMP, MCUCR            ;
   ldi TEMP, 0x00            ;
   out SPH, TEMP         ;
   nop
as the simulator starts with the yellow arrow on the "cli" the Stack Pointer display shows the expected 0x2FF (not 0x4FF). If I then single step to the "nop" I added (what did you think it would do after the "out SPL"?) then, as expected the stack pointer display shows 0x2FF
Either you built for the wrong processor (wrong .include) or you are simulating the wrong processor (selected the on Debug menu with "Select platform and device).
Cliff
PS I guess there's an outside possibility your Studio+assembler is out of date - I use 4.18.716 - aka "SP3"
Thanks Cliff. I forgot I changed to an ATmega88 and never relabeled the schematic. When I changed the simulator platform to ATmega88, it worked.
I don't think I ever would have found it alone. The obvious stuff seems to bite me pretty hard once in a while.
John
