I have a 24V DC motor which I used to PWM speed control using a battery bank as the supply.
I'm now using a switch-mode Power supply and when the motor goes into re-generative mode, ie the load is pushing the motor, the 24VDC rail voltage to too high and I need to clamp this voltage.
My guess is that, at the most, the motor can generate about 3 amps.
Whats a good way of "dumping" this excess energy ?
Cheers
