// Demonstrator.c Joystick version #include "PC_Comm.h" #include "Demonstrator.h" // declare global variables volatile char KEY = 0; volatile char KEY_VALID = 0; volatile char ENABLED = 1; // start enabled void initializer() { // Calibrate the oscillator: OSCCAL_calibration(); // Initialize the USART USARTinit(); // Init port pins DDRB |= 0xD8; PORTB |= PINB_MASK; DDRE = 0x00; PORTE |= PINE_MASK; // Enable pin change interrupt on PORTB and PORTE PCMSK0 = PINE_MASK; PCMSK1 = PINB_MASK; EIFR = (1<<6)|(1<<7); EIMSK = (1<<6)|(1<<7); DDRD = 0xFF; // set PORTD for output DDRB = 0X00; // set PORTB for input PORTB = 0xFF; // enable pullup on for input PORTD = 0XFF; // set LEDs off // say hello sendString("\rPC_Comm.c ready to communicate.\r"); // identify yourself specifically sendString("You are talking to the JoyStick demo.\r"); } void parseInput(char s[]) { // parse first character switch (s[0]) { case 'j': if( (s[1] == 'o') && (s[2] == 'y')) joystick(); break; case 'd': if( (s[1] == 'e') && (s[2] == 'm') && (s[3] == 'o') && (s[4] == '?') ) sendString("You are talking to the LightMeter demo.\r"); break; default: sendString("\rYou sent: '"); sendChar(s[0]); sendString("' - I don't understand.\r"); break; } s[0] = '\0'; } void joystick() { if(ENABLED == 0) ENABLED = 1; else ENABLED = 0; } SIGNAL(SIG_PIN_CHANGE0) { PinChangeInterrupt(); } SIGNAL(SIG_PIN_CHANGE1) { PinChangeInterrupt(); } void PinChangeInterrupt(void) { char buttons; char key; buttons = (~PINB) & PINB_MASK; buttons |= (~PINE) & PINE_MASK; // Output virtual keys if (buttons & (1<<BUTTON_A)) key = KEY_UP; else if (buttons & (1<<BUTTON_B)) key = KEY_DOWN; else if (buttons & (1<<BUTTON_C)) key = KEY_LEFT; else if (buttons & (1<<BUTTON_D)) key = KEY_RIGHT; else if (buttons & (1<<BUTTON_O)) key = KEY_PUSH; else key = KEY_INVALID; if(key != KEY_INVALID) { if (!KEY_VALID) { KEY = key; // Store key in global key buffer KEY_VALID = TRUE; } } EIFR = (1<<PCIF1) | (1<<PCIF0); // Delete pin change interrupt flags if(ENABLED) { getkey(); } } char getkey(void) { char k; cli(); // disable interrrupts so 'KEY' won't change while in use if (KEY_VALID) // Check for unread key in buffer { k = KEY; KEY_VALID = FALSE; } else k = KEY_INVALID; // No key stroke available sei(); // enable interrupts if(k != KEY_INVALID) { sendString("The joystick position is: "); switch(k) { case KEY_UP: sendString("UP"); break; case KEY_DOWN: sendString("DOWN"); break; case KEY_LEFT: sendString("LEFT"); break; case KEY_RIGHT: sendString("RIGHT"); break; case KEY_PUSH: sendString("PUSH"); break; default: sendString("?"); break; } sendChar('\r'); } return k; }
In the initializer routine, various things are done to the ports on B,E & D. Besides setting various registers for the interrupts, do the ports need to be initialized in a certain way?
I ran the code without any of the PORT inits or outputs and it ran fine?
