[TUT][ASM][CODE][PWM] A MORON'S GUIDE TO TIMERS & PWM
5 posts / 0 new
A MORON'S GUIDE TO TIMER/COUNTERS v1.6
by RetroDan@GMail.com
TABLE OF CONTENTS:
1. THE PAUSE ROUTINE
2. WAIT-FOR-TIMER "NORMAL" MODE
3. WAIT-FOR-TIMER "NORMAL" MODE (Modified)
4. THE TIMER-COMPARE METHOD
5. THE TIMER OVER-FLOW INTERUPT METHOD
6. THE TIMER OVER-FLOW INTERUPT METHOD (Modified)
7. THE TIMER COMPARE-MATCH INTERUPT METHOD
8. THE CTC "AUTOMATIC" WAVE-FORM MODE
9. THE FAST PWM MODE 7
10. THE PWM FAST MODE 3 WITH DUTY CYCLE
11. THE PWM PHASE CORRECT MODE
12. TIMER MATHEMATICS
13. FINAL PWM PROJECT: DIM AN LED
Computer timer/counters are used to perform tasks at a set interval. A timer that increments a counter
once every second could be used to make a real-time clock by keeping track of the hours, minutes &
seconds that have elapsed.
For this primer I use the AVR ATtiny13 for its simplicity & small number of pins. This chip has one
timer and one I/O port (Port B) of which Bits 0-4 can be used for output. The ATtiny13 runs at 1.2MHz
( 9.6MHz Oscillator/8 ). The example programs should run on the Attiny25, Attiny45 or Attiny85. The
circuits & code should be easy to adapt to most any AVR Core chips.
To show our progress we connect an LED on Port B, Pin 0 to ground and making it blink. If you use
more than 3 volts, insert a 100-220 Ohm resistor in-line with the LED.
The circuit diagram for our ATtiny13 is:
                   +3VDC      PINOUTS: 1-PORTB,5 (/RESET)
         ATTINY13  |                   2-PORTB,3
          .-----.  |                   3-PORTB,4
        --|1 A 8|--'                   4-GROUND
        --|2 T 7|--                    5 PORTB,0
        --|3 N 6|--                    6-PORTB,1
       .--|4 Y 5|--D LED (PORTB0)      7-PORTB,2
       |  `-----'  |                   8-Vcc
       `-----------+ GND
CHAPTER 1: A PAUSE ROUTINE
A simple timer is a software pause (or wait) routine. They go around a software loop and do nothing
but waste time. By changing the number of times the program goes around the loop we can adjust the
time it spends there.
                PAUSE         PAUSE       PAUSE
  ON:         +------+      +------+      +----->
              |      |      |      |      |     ETC.
  OFF: -+-----+      +------+      +------+
         PAUSE         PAUSE         PAUSE
Here is a program that blinks the LED about twice per second. (An explanation follows the listing).
        ; ATNT_BLINKY1.ASM                                 ;
        ; AUTHOR: DANIEL J. DOREY (RETRODAN@GMAIL.COM)     ;
        .INCLUDE "TN13DEF.INC"   ;(ATTINY13 DEFINITIONS)
        .DEF A = R16             ;GENERAL PURPOSE ACCUMULATOR
        .DEF I = R20             ;INDEX
        .DEF N = R22             ;COUNTER
        .ORG 0000
        ON_RESET:
            SBI DDRB,0           ;SET PORTB0 FOR OUTPUT
        ; MAIN ROUTINE ;
        MAIN_LOOP:
              SBI   PINB,0       ;TOGGLE THE 0 BIT
              RCALL PAUSE        ;WAIT/PAUSE
               RJMP MAIN_LOOP    ;GO BACK AND DO IT AGAIN
        ;PAUSE ROUTINES  ;
        PAUSE: LDI N,0           ;DO NOTHING LOOP
        PLUPE: RCALL MPAUSE      ;CALLS ANOTHER DO NOTHING LOOP
               DEC N             ;CHECK IF WE COME BACK TO ZERO
                BRNE PLUPE       ;IF NOT LOOP AGAIN
                 RET             ;RETURN FROM CALL
        MPAUSE:LDI I,0           ;START AT ZERO
        MPLUP: DEC I             ;SUBTRACT ONE
                BRNE MPLUP       ;KEEP LOOPING UNTIL WE HIT ZERO
First the assembler reads the file TN13DEF.INC that contains standard definitions for the Attiny13,
then we add some of our own definitions for registers that we use.
        .DEF I = R20             ;INDEX
.ORG tells the assembler we want our program at bottom of memory (since we have no interrupts):
        .ORG 0000
We use bit zero of Port B as output, so we write a one to the first bit of the Data Direction Register for
Port B (DDRB):
     ON_RESET:
In the main loop we flip the 0-bit of Port B then call the pause routine in an infinite loop:
        MAIN_LOOP:
              SBI   PINB,0       ;FLIP THE 0 BIT
The next two subroutines waste time by going in loops. The first PAUSE routine calls the second
routine (MPAUSE) to slow things down so we can see the LED blinking. Both routines load zero into a
register then repeatedly subtracts one until it hits zero again (subtracting one from zero gives 255):
CHAPTER 2: WAIT-FOR-TIMER "NORMAL" MODE
Next we use the chip's timer. When operated in "normal" mode, it will count up from zero to 255 then
set an over-flow flag. So we wait for this flag to be set each time. I think a lot of the confusion about
timers could be eliminated if everyone just called them counters instead. They are counting circuits that
people use to create timers.
                       FLAG             FLAG
                0      255      0       255
     ON:        +-------+       +-------+
     OFF: ------+       +-------+       +----> ETC.
          0     255     0       255     0    255
                FLAG            FLAG         FLAG
We set a "pre-scaler" to 1024 that divides-down the system clock by 1024 so we can see the LED
blinking. I think a lot of confusion about pre-scalers could be avoided if they were just called dividers
instead. Note, setting the pre-scaler also activates the timer/counter.
            LDI A,0b0000_0101    ;SET TIMER PRESCALER TO /1024
            OUT TCCR0B,A
The rest of the code is the same as our last program, except for the PAUSE routine. This time we wait
for the timer to overflow past 255 (and the overflow flag gets set). Then we reset the flag. To reset the
flag we write a one (not a zero):
         .ORG 0000
        ON_RESET:
            OUT TCCR0B,A
        MAIN_LOOP:
              RCALL PAUSE        ;WAIT
        PAUSE:
        PLUPE: IN   A,TIFR0        ;WAIT FOR TIMER
               ANDI A,0b0000_0010  ;(1<<TOV0)
                BREQ PLUPE
               LDI  A,0b0000_0010  ;RESET FLAG
               OUT  TIFR0,A        ;NOTE: WRITE A 1 (NOT ZERO)
                RET
CHAPTER 3: MODIFIED WAIT-FOR-TIMER "NORMAL" MODE
The last method provides us with only five speeds, because the pre-scalers can only be set to five
values (1,8,64,256,1024). For more control we can pre-load the counter to any value from zero to 255,
this will shorten the time it takes to reach 255 and over-flow. In the example below we pre-load timer
with 128 each time.
                       FLAG        FLAG
                 128   255   128   255
       ON:       +-----+     +-----+
       OFF: -----+     +-----+     +---> ETC.
           128   255   128   255   128   255
                 FLAG        FLAG        FLAG
For example, to blink the LED twice as fast we pre-load the timer to 128 with the following two lines:
              LDI   A,128        ;PRELOAD TIMER WITH 128
              OUT   TCNT0,A
Our modified program goes twice as fast and our MAIN routine now looks like this:
         ; MAIN ROUTINE ;
        MAIN_LOOP:
              RCALL PAUSE        ;WAIT
              OUT   TCNT0,A
CHAPTER 4: THE TIMER-COMPARE METHOD
(CTC MODE CLEAR-TIMER-on-COMPARE)
The next method is very similar to the last. This time we set a "compare" value and a flag goes off
when the timer reaches this value instead of 255. This simplified our program because we don't have to
reload the counter each time.
                       MATCH       MATCH
                 0     128   0     128
       ON:       +-----+     +-----+
            0    128   0     128   0     128
                 MATCH       MATCH       MATCH
First we configure the timer into "CTC" mode and set the pre-scaler to 1024:
            LDI A,0b0100_0010    ;SET TO CTC MODE
            OUT TCCR0A,A
            LDI A,0b0000_0101    ;SET PRESCALER TO /1024 AND
            OUT TCCR0B,A
We need to set the compare register to the value we want. Once again we use a value of 128:
            LDI A,128            ;OUR COMPARE VALUE
            OUT OCR0A,A          ;INTO THE COMPARE REGISTER
Then we wait for the compare flag to be set. (Note that we are waiting for a different flag this time):
            PAUSE:
                   ANDI A,0B0000_0100  ;(1<<OCF0A)
                    BREQ PLUPE
Finally we reset the compare flag after it is triggered, (to be ready for the next compare):
          LDI  A,0b0000_0100  ;CLEAR FLAG
          OUT  TIFR0,A        ;NOTE: WRITE A 1 (NOT 0)
           RET
The resulting code should now look like this:
        .ORG 0000
       ON_RESET:
           LDI A,0b0100_0010    ;ACTIVATE CTC MODE
           OUT TCCR0A,A         ;SET FLAG ON COMPARE MATCH
           LDI A,0b0000_0101    ;
           OUT TCCR0B,A         ;SET PRESCALER TO /1024
       MAIN_LOOP:
             RCALL PAUSE        ;WAIT
       PAUSE:
               BREQ PLUPE
               RET
For the remaining chapters I invite you to download the PDF version below:
(You must Login to see the Files)
Visit AVR Assembler site http://avr-asm.tripod.com
.org 0 I was wondering about that. I knew that interrupt vectors where around down there. I tend to just let the assembler gavrasm deal with the org issue. Another great tutorial. Even though I use a atmega8 the code works fine with it, just needs a few weaks here and there.
Cheer
Rich
very nice tutorial i had trouble with timers but it really helped
eager to learn
Awesome some example ASM code! Can I use inline assembler in the C dev tools? I havn't installed them yet........... Also I don't understand BREQ PLUPE is this the cpu function that does the compare? I'll have to read up on AVR asm.........
Total votes: 2
AS7 comes with two assemblers, use the Atmel one if you want to do Asm alone. Only if you want to mix C/C++ and asm then use avr-as instead.
Get the AVR Opcode Manual which will explain BREQ (Branch if equal to 0) and all other AVR opcodes.
Finally read www.avrbeginners.net
