strstr() function bugs
5 posts / 0 new
Hey Guys,
Can someone help me with this small gcc problem.
Im connecting to gsm modem and trying to check when i receive a new sms. at this stage i ma just checking data between the microcontroller and computer terminal.
a small issue with the strstr() subroutine... When a correct comparion is made it enters the if loop. But it also enters when its comparing with a carriage return(enter key pressed).
can some one shine some light.
void CheckForSms()
	char ser[]="+CMTI";
	char s[64];
	int n;
	n = UART_gets(s, 6);
	s[strlen(s)-1] = 0;
	if (strstr(ser, s))
		UART_puts_P(PSTR("\r\nFOUND at index "));
		n = UART_gets(s, 5);
		UART_puts_P(PSTR("\r\n"));
		UART_puts_P(PSTR("\r\nAT+CMGR="));
		UART_puts(s);
hi rodney,
i would try:
void CheckForSms()
  char ser[]="+CMTI";
  char s[64];
  int n;
  if (n>0)
	 s[n]=0;
	 if (strstr(s, ser))
		UART_puts(s);
Angelo
Are you sure that the CarriageReturn gets through to the array s? Could it be that it is stripped out and that the lenght of the string in s is zero?
From the strstr documentation
If s2 points to a string with zero length, the function shall return s1.
( http://www.opengroup.org/onlinep... )
yes thats one thing solved
Thankyou Spectrum and JohanEkdahl.
Much appriciated
s[strlen(s)-1] = 0;
Just thought I'd mention that this piece of code would not work well for adding a zero termination to the string s since strlen relies on the string being zero terminated in order to give you a length.
