FreeRTOS disabling level 0 interrupts
3 posts / 0 new
I'm building an application where I must generate several signals with quite precise timing (about 1us resolution). As I have too many signals to generate I can't use PWM channels. So I decided to generate the signals in a timer interrupt. That works OK, but I found out my interrupts had some jitters, and noticed this jitter was caused by FreeRTOS disabling interrupts.
The solution I found was to transform the port code, from this:
#define portDISABLE_INTERRUPTS()  DISABLE_ALL_INTERRUPTS()
#define portENABLE_INTERRUPTS()   ENABLE_ALL_INTERRUPTS()
to this:
#define portDISABLE_INTERRUPTS()  DISABLE_INT_LEVEL(0)
#define portENABLE_INTERRUPTS()   ENABLE_INT_LEVEL(0)
I configured a higher priority for my timer interrupt, and now FreeRTOS is not disturbing it.
So here comes my question : do you think it's safe to just disable the lowest level of interrupt? May that break something if an interrupt occurs in an OS critical section?
Julien
Open Servo Control Board: http://openscb.org
I finally found out the answer, it was in the documentation of configKERNEL_INTERRUPT_PRIORITY on http://www.freertos.org/a00110.html.
From what I understand, this modification is safe only if the higher priority level interrupt handlers do not use any OS function.
Julien
Correct. As long as the level 0 interrupt level does not change any operating system structures everything will work fine. Otherwise, you could have a race condition where a low-level task in a critical section becomes interrupted while modifying some OS structure and the two changes lead to some undefined behavior.
