Float to String
5 posts / 0 new
I have to convert a Float to a string, but I didn´t find any function for
this. Has someone an idea, how to do this.
If its too difficult I could also use a function which converts an integer
to an string. I have found a function in stdlib.h "itoa" but it doesn´t work.
Perhaps I have used the wrong parameters. How must I use this function?
Regards
Thomas
admin's test signature
Check the projects. I added a C routine that does this without needing libraries.
What I'd done was simple - i designed a int2str function and multiplied the float 10x or 100x or whatever precision I needed, then converted the float to int, then fed it into int2str, indicating that the last 1 or 2 digits should be behind the dot .. easy as pie ;)
Wow, that is great!
You do realise you are replying to thread that's more than 8 years old?
Moderator.
(and I'm not entirely sure I see what's "great!" about the OP anyway?)
